Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
Top element wont heat wen oven is on bake
Stove electric fridgidaire gallery model # FG778W-2 SERIE#NF52003913
Posted by bourdonr on
Cool Blue Services
  • 560 Answers
The top element normally operates only when you turn the temperature control all the up to the broil setting as it is the broiling element. If it doesn't work at the broil setting, suspect a bad brioler element or a faulty temperature control.
Posted on Aug 12, 2009
Where are the fuses on a fridgidaire stove CFEF312AS4 model it is in our rental unit
Call "SearsPartsDirect" and ask them.
I have not heard of stoves having fuses.
I could not find your make & model on the Sears web-site.
Perhaps you can.
Stoves usually depend on the circuit breaker for the electrical panel for the house or apartment to regulate the current.
God bless your efforts.
Feb 09, 2018 | Kitchen Ranges
Fridgidaire stove clock not keeping correct time
Clock logic can not be changed replace the whole board
just lets you change the time will not let you slow it or speed up
Nov 14, 2013 | Frigidaire FGGF3054KF Gallery Series...
I have a frigidaire gallery stove.I need a temperature sensor . Model No. PFEF385JFT3.Serial No.NF82105720.Where can I get one.How much is it?I believe this stove was puchased in Canada.
According to the Frigidaire website the place in Canada where parts can be obtained from is
Frigidiare Parts& Service
7075 Ordan Dr.
Mississauga,Onterio L5T 1K6
Tel# 905-565-9200
GENE
Sep 22, 2011 | Frigidaire Gallery GLEFM397DS Electric...
My Fridgidaire Gallery dryer is excessively heating up when we use it. I have cleaned all the vents, so I assume it is a bad thermostat.
my maytag electric stove oven door is locked, i tried pressing cancel, unplugging the stove from wall and it still will not open!! I was not in cleaning mood, it just locked on its own!! help, i cant use the oven!!
Jan 07, 2011 | Frigidaire Kitchen Ranges
Electrical panel went blank. Hence can't operate the oven. Stove works fine.
Hi. Interesting. My Figidaire Gallery Professional gas stainless went blank 2 days ago. Model FGF379WECS. So I'm googling...
Your Service Manual is located at (document #2 in link):
http://www.retrevo.com/support/Frigidaire-GLEFM397D-Ranges-manual/id/2367bh351/t/2/
Part Number
316418704
Description :
Clock/Timer, electronic, w/mini oven, ES510
Rick
May 15, 2010 | Frigidaire Gallery GLEFM397DS Electric...
The oven does not heat up. broiler and cook top is working.
Check to see if the oven elements work, take out the racks and check if the black tubes on the top and bottom have ripped.
Aug 05, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Want to clean under stovetop
Hello
welcome to Fixya,
This stove has sealed burners and there is no need to lift or clean under anything except the burner caps.
You can not get inside the top and you can not lift the top like the old pilot stoves!
When you clean the burners and around rings do not spray or saturate the are and or the igniter element that creates the spark.I'll be back in a moment with your user manual.
first what is the complete model number of your range as written on the sticker in the door jam of the storage compartment down below. left side!
Huuum
Dec 15, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
680 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
