some routers dont have wps button but if you need to reset router To restart the Dell TrueMobile 2300 Wireless Broadband Router, unplug the power connector and plug it back in.
To load the Dell TrueMobile 2300 Wireless Broadband Router's default settings, hold down the reset button on the router for at least five seconds. While the unit resets, the Power light blinks.
Dear Friend,
You must be trying the WEP -OPEN.
try WPA-PSK and put in your customized password.
Before making any changes in the system remove all the cables from the router and reset the router once and try to configure the network with WPA- PSK.
It should work.
If negative plz contact your ISP
To isolate the problem try installing the adapter to a different computer and if it works there it could be that your card slot is defective. As for the router try to reset it
you need to change dhcp from the modem to the router to be a different network than what your router hands out via dhcp. you will also need to set dns up in the router to forward to the upstream modem.
This is usually a router configuration issue. The router has to be configured to match your new broadband settings.
For example, your old DSL may have required some kind of login which was entered into the router. For most broadband cable connections, you set the router to get an IP address automatically.
Re-run the router Setup Wizard. You can download it here:
Before you throw it, save all the settings in router and try a re-start or there is normally a re-set button somewhere to press and set it back to factory settings.
If the wireless re starts re-load previous settings.
Please rate solution.
