Whirlpool awm 9000 auto front loader washing machine after start on express load it shows 35 minutes countdown time. mahine fills with water and starts wash cycle.when machin counts down to about 21 mins to go it switches off time and shows flashing f h and beeps
I had the same problem ,it took me a few hours running through the cycles but finally sussed it for answerI had the same problem ,it took me a few hours running through the cycles but finally sussed it for answer
The error code F/H for this machine means that the drain pump is blocked. Look at your manual for how to access the drain pump and clean it out. This will resolve your issue.
Hello mi_wilk64,
If you still need assistance with this concern, please reach out to us, we have a local rep for you to speak with, here is our link: http://www.whirlpool.eu/ Thank you Whirlpool Social Media
If your machine is reasonably old, perhaps take a look at the bushes of the motor . Before that, take the manual and run the test cycles by following the instructions; it might provide you with answers
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Front Loading Washing Machine: Fully automatic. 1. Better washing than toploading as technologically proofed. 2. No extra effort except putting cloths and detergent inside.3. No need to observe
in between while washing.Start and forgot. You can go market and come back. 4. No issue if electricity or water went out during washing. 4. Take more water compare to toploading semi-automatic. 5. You can not open it once it started.
Top Loading Washing Machine: Semi 1. Save water and detergent. 2. Need extra effort to put the cloth from one box to another.
Front Loading Washing Machine: Fully automatic. 1. Better washing than toploading as technologically proofed. 2. No extra effort except putting cloths and detergent inside. 3. No need to observe in between while washing. Start and forgot. You can go market and come back. 4. No issue if electricity or water went out during washing. 4. Take more water compare to toploading semi-automatic. 5. You can not open it once it started.
Try checking for good water supply.
Pull out detergent tray and check for good water supply during filling.
if poor filling-
Try checking the hoses.
Turn taps off, disconnect from machine, place hose end in sink, turn tap on and check for good water flow.
if the hose has a red indicator in the side of the hose (end which is fitted to the tap) - Red indicator is a failed hose.(for models with Water Stop hose type "B")
Your water pressure may be a liitle too high for the machine to handle. Try turning the water valves for the hot and cold water down a bit to reduce the pressure and try it again.
[email protected] to solve the problem
