Question about Radio Communications
I have a Tao Tronics TT-BR05 that my bluetooth will not recognise. The unit is on and the light is flashing blue/pink
Posted by Susan Maxwell on
2 Related Answers
darkoh69
danny
  • 77 Answers
SOURCE: Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Posted on Jun 01, 2009
Anonymous
SOURCE: bluetooth n136 does blue light flashing mean to
looking for parts motorla N136
Posted on Oct 09, 2010
I have a Tao Tronics hedset TT-BH01 and I can't get it into pairing mode. I have tried for 2 days.
I don't know if this is the problem you are having, but I had trouble figuring out how to get the headset into pairing mode. The problem is the manual is wrong! It says to turn the headset on, and then hold the function key for 8 seconds to turn on pairing mode--but holding the function key for 5 seconds just turns it off! After searching under some other models, I figured out that you have to hold the key for 8 seconds while it is off and then it will go directly into pairing mode. Hope that helps!
Aug 18, 2013 | Radio Communications
Why wont my logitech boombox go into bluetooth search mode
I had the exact same problem. Boombox flashing blue, but not rapidly flashing blue. I did two things that seemed to fix it:
1: Reset the device by switching it on, then holding both volume up and volume down buttons at the same time for 10 seconds. The blue flashing light will briefly flash quicker to confirm.
2: Switch off the boom box
3: Switch on using the power button and (very important) immediately press and hold the Bluetooth button. The Bluetooth button needed pressing and holding almost instantaniously after the power button for it to work for me. I had to try several times to get it to work.
When you do this successfully, the Bluetooth light starts flashing rapidly and it enters search mode.
I nearly threw my speakers away, now it works and connects fine :)
Oct 10, 2012 | Logitech Radio Communications
H620 flashes pink 10 times when turned on. I have charged the unit and had a green indicator, Any idea what the flashing pink means when turned on.
if the flashes are rapid, normally it means that the connection was successful. A quick google search for motorola h620 should bring up the users manual in pdf format with an explaination of all the light combinations
Feb 01, 2011 | Motorola Mobility H620 Bluetooth Headset
Lg l I will not pair with plant tronics headset
hi sarzim take the battery out of the lg phone .. Once youtake the back off check to make sure the is no dirt or any foreign obstacle in the contacts . Next put the battery back in the hone. The next thing you want to do is go into the settings and go to wireless settings. Next go into bluetooth make sure is is in sidcoverable mode scan for devices. ON the plantorics make sure that bluetooth is flashing back and forth two colors. Once all this is done the phone and bluetooth should pair together.You need the pplantroincs blue tooth to have a good charge and the liightd flash back and forth it becomes one color when it is pair with the phone.the code is 0000.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Nov 26, 2010 | LG Ally Cell Phone
Pair bluetooth em227 with my phone
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above. Then you can discover it with your phone. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Mar 05, 2010 | Southern Telecom Emerson Bluetooth Headset...
Jun 01, 2009 | Western Digital My Book Essential 1TB...
Alpine IDA-x100 and KCE-300BT
Hi
what you need to do is to start off make sure both units are powered from the same point you will see why below. Make sure you connect the Audio Interrupt out lead (pink/black) from the 300bt to the x001 INT IN pink/black wire
Go to general settings turn off the int mute setting, (you proberly have it turned off already the reason your not seeing it) try resetting it using the small button behind the face plate. This should allow you to see the int mute setting. Go to the bluetooth settings and select adaptor. Disconnect power to both units. ( you will need to re apply power to both units at the same time) after around 10mins. when you re-connect the power make sure ALL bluetooth units around the car are turned off. You should now have success in pairing the phone and having the X001 recognise the 300 bt.
Feb 20, 2008 | Car Audio & Video
Blue tooth
providing the mobiles that your trying to connect to are, bluetooth capable devices themselves. it,s the matter of getting the 2 devices to find or recognise each other ( connection Manager ) or device enabled settings.
If your mobile phone is Infa red then the 2 are incompatable. This can sometimes be determined via a little blue flashing light ( hence Bluetooth )
refer to your PDAs user and instruction guide for further assistance.
Mike @ compurepair.
Jan 08, 2008 | Acer N300 Pocket PC
LG BLUETOOTH HFB-300 connection problem
turn the unit on using the large button that has a phone on it. once the unit is on then put your phone into "pairing mode" (see phone instructions for how to do this) and then hold the "mute/function" button for up to 10 seconds until it beeps and the blue light flashes on and off every one second. then your phone will discover the unit and ask for the passcode which is 0000, enter this on your phone and the pairing will complete with a beep from the HFB-300. the unit will pair up to 3 phones in the same way and will only recognise 1 phone that is on at once so you need to only switch bluetooth on for one phone at a time. if you pair more than 3 phones then the unit will automatically drop the oldest existing one it already has stores
Oct 29, 2007 | LG BLUETOOTH? HFB-300 NOISE CANCELING...
Radio Communications Logo
128 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
