The tail & brake lights stay on even when the engine is turned off. The only way to turn the lights off is to take the fuse out.
The plastic round stopper most probably broke that is were the stoplight switch sits when not depressed easy fix find a washer small enough to block the hole were the original plastic stopper was making sure the washer aligns to the brake light switch and secure washer w/ zipties hope this helps.
You need a brake light stop switch. it is located on the brake pedal at the top. really easy to change out.
SOURCE: tail lghts/brake lights
Isn't that mysterious? It took me a few weeks to figure it out. Look carefully under the break pedal. There is this device called a "break light switch". I hope that helps.
replaced brake light switch but still have same problem.
