Acer Aspire 5610-4648 Notebook Logo
Question about Acer Aspire 5610-4648 Notebook
WHEN BOOT UP ON MY ACER ASPIRE THE SCREEN REMAINS BLACK, IS THERE A SOLUTION TO FIX IT?
Posted by paula_dp on
Anonymous
I had the same problem with my Aspire One, and I found at other forums that I needed to update the Flash BIOS, I did it and it worked just fine...
Posted on Aug 11, 2009
Anonymous
  • 61 Answers
If the screen stays completely black, shine a bright light on the screen, can you see the desktop at all? If you can see the desktop when shining a bright light on the screen it is likely an inverter board which on most laptops is inside the case of the LCD, if you still cannot see any image with the bright light shining on it then it is likely that your LCD has gone bad and needs to be replaced.
crazytony777
    Sergeant:
    Champion:
  • 257 Answers
If you have the restore cd for you computer run it and follow the directions,, if not thats it repair shop
Black screen
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
I have an acer aspire 5532, everytime I turn it on the power button will light up but the screen remains black. Is there an easy fix for this?
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Acer Aspire 5100 laptop's screen remains black at start-up
This is probably a hardware issue with the monitor. Just to make sure, uninstall, and reinstall the monitor's driver. If that doesn't fix it, it's a hardware issue.
You will have to either take it to a shop, or contact the manufacturer (your computer should be under warranty if you've had it for less than a year).
Computer does not boot
After replug the graphic card and switch on the pc & install back the graphic ... The power button remains green but the screen is black. ... From what i have noticed there is probably some issue with the thermal cutout ... Lights light up, Drive sounds as if working,
2answers
ACER ASPIRE 5100 WONT BOOT
Your harddisk MBR sector might be damaged, google fix mbr and resetup your harddisk mbr. After that it most likely will boot.
Acer Aspire AM1201 Desktop won't boot
It would definatly fall under a warranty problem. I would definatly consult the retailer or manufacture prior to anything else
Steve Sweetleaf
Steve Sweetleaf
shadow
