Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Defrosts/refreezes I have a 5 year old Whirlpool fridge. About 4 months ago, I noticed there was water in the back of the fridge under the area where there's a hole from the freezer to fridge. I put a bowl under it and every few days, there'd be a frozen ice chunk in the bowl usually surrounded by water. There would usually be a thin layer of frozen water in the freezer area too. But I never noticed anything being warm. Today when I came home, I opened the fridge and everything was defrosted... there was water in the freezer bottom again and all the ice was melted. So, I'm assuming my fridge is defrosting and refreezing on a periodic basis? Any clue what could be causing this?
Posted by txthunderbir on
Anonymous
  • 67 Answers
IF YOU TAKE THE BACK PANEL OFF INSIDE THE FREEZER YOU WILL FIND A PIECE OF METAL UNDER THE EVAPORATOR COILS IN MIDDLE OF THIS METAL PAN IS A HOLE THAT LEADS THE WATER TO THE BOTTOM OF THE REF FOR EVAPORATION THE HOLE IN THE PAN IS PROBABLY PLUGGED TAKE THE ICE OUT AND CLEAR THER HOLE
Posted on Aug 11, 2009
The water dispenser is not putting out water and ice maker is not making ice. The fridge frequently cycles like it is trying to send out water.
it's still under warranty for up to 1 year,call whoever you bought it from and it should be repaired free of charge and next time you write send model number.
Dec 08, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool model-ER2MHKXPL02 serial-ES3330121 water accumulates in fridge portion top shelf. recent problem did not occur til 1 month ago. no ice maker installed. Also some ice in freezer around vent to...
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
Jul 06, 2008 | Whirlpool Refrigerators
About a month ago we noticed that there was water on the food in our refrigerator and that ice was building up in the freezer. Today when i went to get ice cream out of the freezer I noticed it had...
I thoguht I had posted the solution. repeating now ask for estimates/ inference from thre persons and deccide for only low cost of repair. If your fridge is more than 5 years old do not proceed specially if the pumping of the compressor is down. Go for a good exchange with a the modern enerrgy effficient models as you can choose from good economic/ luxury ranges and give you about 5-7 years warranty.Invest Well. Good Luck
Jun 28, 2010 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Whirlpool side by side Fridge Freezer S20BRBB20
Your fridge is simply not defrosting itself or moving air off the freezer coil. Try defrosting it and make sure the fan is operating. If the brains have been replaced already i do not think you should have to deal with them again unless consumer reports suggest otherwise.
Apr 30, 2010 | Whirlpool GC5NHAXSQ
Whirlpook ET21NK--Water collecting in crispers
Self-defrosting refrigerators turn themselves off to defrost once in each 24-hour cycle. There is a 'drip pan' under the refrigerator that catches water from this automatic defrost cycle. The pan is not very deep, so if the unit is leaning very much, water will run over the top of the pan. For this and other reasons, you should try to keep the unit as level as possible.
Aug 21, 2009 | Refrigerators
Flooding when freezer defrosts
Make sure the refrigerator is level and the drain tube is not clogged. This is the most common cause of water pooling.
Jul 29, 2009 | Refrigerators
Whirlpool refrigerator w/ top freeezer
It has a plugged defrost drain. You may need to defrost for 24 hours with unit unplugged and doors open. UNPLUG FIRST!! f still leaks, you need to remove floor of freezer, then the back wall of freezer. Remove ice. At center rear under coils is the drain hole that is plugged up. Use hair dryer to melt ice. Pour hot water in this area to uncover drain. With hot water in area, you can put a 1/4 diam. hose or copper pipe in drain and blow into it while pressing down. It will slowly go through ice, clearing drain.
Nov 17, 2007 | Whirlpool ER6AHKXPQ Top Freezer...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
296 people viewed this question
Top Whirlpool Refrigerators Experts
Michael Thomas
Michael Thomas
jdthefixer
Marvin
Marvin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
