Question about Zenith Z37LZ5D 37 in. LCD TV
I have a TV LCD Model L17W36. and it has trouble with the picture; the sound is ok, but it has many color lines but no pictures. What I do for it?
Posted by luzvillafran on
romy sibug
  • 269 Answers
You trouble on the cpu unit. try reheating it with hot air.
Posted on Aug 11, 2009
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Vertical colored lines on entire screen, sound ok
Hi.
Probably the t con board of your TV is faulty. T con board is the one which drive the lcd pixels. You have to replace the T con board to get it work properly.
Here i have added the picture of the T con board of your tv for reference.also added the video to know how to replace the T con broad.
RCA L32WD22 T-CON BOARD UT-5531T03088-76J
Samsung TV Repair How to Replace Con Board in LJ94 02 705E Model How to...
www.electro-medical.blogspot.com
Sep 09, 2015 | RCA L32WD22 32 in. LCD HDTV
Verticle colored lines, No picture
Well it sounds like your tv is having trouble with your color wheel, this is the part that send the color to your tv, if its defective or its malfunctioning, one of the symptoms will be weird colors one the screen, and if you touch the tv you will fell the tv vibrating.
Sep 09, 2009 | Televison & Video
Polaroid FLM 3232 Color problem
If you typed in the right model number this is a LCD TV and won't have a color wheel...Check all the power supply voltages and see if they're all ok, if they are I'd replace the main board and see if that fixes it since you don't have sound or picture
Mar 07, 2018 | Televison & Video
No picture
Bad inverter or backlights.
cheaper to buy a new monitor
Mar 02, 2009 | Zenith L17W36 17'' LCD Flat-Panel HDTV...
JVC LT 42x688 no picture just sound
Sorry, this has no easy fix. The good news is you do not need an LCD Panel. The bad news is the Video Processor has a problem.
This TV has x3 Boards. The one you should replace first is the one in the middle. If this doesn't fix it, try the one on the right. The Part #s are on the Boards if you wanna try ebay.
Dec 22, 2008 | JVC LT-40X776 40 in. LCD HDTV
Repairing lcd tv.
thanks very much about your technical support.but i solve allready the problem of LG LCD TV MODEL LT-15A10 TROUBLE; no picture with sound, i replace the socketed ic SDA555XFL62 PINS. THANKS... LODIVAR.
Feb 17, 2008 | Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD...
Lcd tv
What is the make and model number of your set? I may b able to help you. desribe in more detail is the picture gone entirely and you only see colored horizontal lines on ablack screen?
Jan 21, 2008 | Televison & Video
Tv picture
Hi
Most likely reason, Picture tube.
Capital98
Dec 14, 2007 | Televison & Video
Zenith Z37LZ5D 37 in. LCD TV Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
