Question about Pioneer Car Audio & Video
I have a pioneer AVH-p2300dvd. is it compatible with playing an audio cd?
The system came with a used car purchase. The unit makes a clicking noise and then spits out the dvd or cd. it won't play either one.
Posted by Brenda Edmontson on
Franco Dosil
    Top Expert:
  • Pioneer Master
  • 10,535 Answers
Hello Brenda, if the Pioneer AVH-p2300dvd, can read both DVD, audio CD and also mp3 CD
In the case of your device you have a problem in the input and reading of the discs
I suggest you consult with a technical service specialized in this type of equipment, preferably a Service Pioneer
I hope you can solve the problem
Greetings Franco Dosil
Hola Brenda, si el Pioneer AVH-p2300dvd, puede leer tanto DVD, como CD de audio y tambien CD mp3
En el caso de tu aparato tiene un problema en la entrada y lectura de los discos
Te sugiero consultes con un servicio tecnico especializado en este tipo de equipos, preferentemente un Service Pioneer
Espero puedas resolver el problema
Saludos Franco Dosil
http://www.pdfmanuales.com/manuals/487020/pioneer-avh-2300dvd.html https://www.pioneerelectronics.com/PUSA/Unassigned-Content/Manuals/AVH-P2300DVD+OWNERS+MANUAL
Posted on Jun 20, 2019
5 Related Answers
Anonymous
  • 52 Answers
SOURCE: cd/dvd player noise
Something could have been misalligne or not sitting properly in the DVD rom...if the grinding sound is mechanical. The only possible way to cure this is to open the DVD ROM and service its mechanism. Observe DISC that is played if there's any sign of scratches...sign tells that its touching or rubbing something.
Good Luck.
Posted on Jan 03, 2008
Anonymous
SOURCE: ipod will not play video to my head unit AVH P5900DVD
ok for the first post with the ipod not showing video .. make sure that you have the correct cable running from behind the deck to the ipod .. (iPod Direct Control (CD-I200 Required) once you have that connected you need to go to the video settings of your ipod and turn on the video out .. by default its offf... also remember with movies on your ipod .. that has to be manually selected from the ipod itself .. you cant control the videos from the pioneer unit.. only the audio/music on your ipod can be selected from the pioneer unit..
Posted on Aug 06, 2008
Anonymous
SOURCE: pioneer AVH-P5000DVD
**** it
Posted on Aug 07, 2008
Anonymous
  • 3 Answers
SOURCE: ERROR CODE 02-60 WHEN TRYING TO PLAY IPOD.
I had the same exact problem with the 4100DVD I got on 5/01/09. I reset my Ipod via the Itunes software. This will wipe your Ipod clean and reinstall everything. I was a bit leary about this but gave it a shot and viola! It is working just as it was when I first purchased 5 days ago.
Make sure you back up your Ipod first. After the reset, it will ask if this is a new install or restore. Select restore and everything is back again, including downloaded games and app. (I have an Ipod Touch)
Posted on May 07, 2009
Anonymous
SOURCE: No videp playback on Pioneer AVH-P4000DVD only getting sound !!!
Just wanted to add my 2 cents for those who might be having the issue of no video but hear audio. I was having the same problem. I had completed the bypass hack with a single throw/single pole (SPST) toggle switch. I could bypass the warning message and hit the OK button but no video. I did hear audio. I searched everywhere but solution 4 worked for me. The thing for me was that next to the black wire on the harness wasn't empty. It had a purple/white wire with some sort of filter (labeled backup camera hook to reverse gear). I tied into this wire before the filter with another wire (I chose a black wire b/c I was grounding it) and grounded it with the black wire (ground) on the harness. I now have video! Maybe the 4 pole relay hack would have worked better but I had only done the toggle switch hack. I hope this helps others and most importantly thank you Salhi.
Posted on Aug 22, 2009
Advent troubleshooting
ours did the same thing but kept the dvd, we had to replace it, dvd player gears went...
Dec 21, 2013 | Advent Adv38fr Flo Tv Ready 10.2 Inch...
Chrysler grand voyager dvd in car system won't
Does it play a cd? If so than the decoder for the dvd portion of the head unit may be bad. I would replace it if that's the case.
Jun 17, 2013 | Cars & Trucks
Won't play dvds
do you have any software that play multimedia? or Power DVD any version or is your player also cant read any dvd disk at all? why not try to clean the lens, but be careful the lens is sensitive.
May 24, 2011 | HP 5188-7537 DVD Writable CD-RW...
Toshiba Regza 32LV67U DVD player won't play DVD. put dvd in, it makes 3 attempts to read then spits it out. Can I fix this or is this a take-it-in for service issue?
dvd player will only play movies for the COUNTRY in which you purchased it. There is no way to purchase a system or configure a system to play ALL MEDIA FOR ALL COUNTRIES. The country codes are specific and each country wants to prevent any other country from playing their dvds music, etc.
Jan 27, 2011 | Toshiba Regza 32LV67U 32 in. LCD HDTV
The DVD will play for awhile then it stops, gets stuck and the media will make clicking noises. Had tried our DVD drive cleaner, thought it helped, but same problem. We just bought this system. We have...
CD/DVD readers have an optical lense and laser that travel on a track as the CD/DVD spins above (or in blu ray above and below) it. The track is about 4 inches long or the width of the CD. It reads from the inside out on a DVD like a record player. The lenses are mounted on gears and it sounds as if they are travelling half the track and running into a physical obstacle that is preventing them from going further.. such as a damaged gear, dirt or debris in gear/rail, etc. The clicking noise is the motor in the head unit trying to move but its not able to overcome the obstacle. If the unit was bought new this is a warranty issue and BOSE will correct it as a product failure. If the unit was bought used then BOSE will still correct but for a fee. Dependent on model of drive used inside the DVD system the cost is going to be more labor than the drive itself, plus shipping. The link to BOSE support is http://www.bose.com/controller?url=/customer_service/index.jsp
Try the FAQ's and if that fails then contact customer support at the bottom link on the support page.
Good luck
Jun 03, 2010 | Bose 3 2 1 GSX System
My home theater system plays cds but will not play dvds, what can I do to fix it, makes a scratching noise when i put dvds in it, but plays fine with a cd.
There is something wrong with the DVD drive assembly inside. If you're brave, take it apart and check on what is making the noise. Also, try using a q-tip to clean the laser head if it's accessible.
If that doesn't help, it's time for a new DVD player.
This is why I always recommend people buy a home theater system without a DVD player built in. The DVD player is the weakest link, and stand alone DVD players can be purchased for as little as $25 depending on if you want upconversion or not.
If you cannot get the DVD player working in your surround system, just replace it with a stand alone DVD player, if you can, check to make sure there are audio inputs on the back of the receiver. If there are no audio inputs on the receiver, you will have to get the entire surround system replaced. If so, purchase a separate DVD player and surround system.
Jan 13, 2010 | LG LH-T754 Theater System
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
CD Error
No the loading mechanism has failed, it is a complicated peice of design and they are the most common thing to break on all CD players, you will have to pull the unit and send it out for repair at an authorized GM radio repair center, they are in the phone book and on line under car radio repair
Sep 06, 2008 | 2001 Cadillac DeVille
Portable dvd doesnt play movies
Try cleaning the lasers lens with an anti static cleaning wipe. I used " nice'n clean" that I had purchased from Walmart to clean my laptop screen. My dvd player started back playing after gently wiping the laser lens.
Jan 05, 2007 | Apex Digital PD-450 Portable DVD Player
Car Audio & Video Logo
142 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
