Microsoft Xbox Console Logo
Posted on Aug 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a xbox 360 hdmi and it has flashing red and green lights what is this and how can i fix it. thanks
Anonymous
Level 2:
  • Expert 149 Answers
  • Posted on Aug 11, 2009
Anonymous
Expert
Level 2:
Answers
149
Questions
Helped
45975
Points
451
Hi, how many red lights are there? the number of red lights represents a different problem with your system. the most common is 2 red lights which means your system is overheating. 3 red lights which is commonly known as the red ring of death which means your x-clamps need replaced. and 4 red lights which means your a/v cables aren't hooked up. If it is 2 or 3 red lights then you need to take it in and have it serviced. the 4 red lights just check your connections and make sure they are secure.
Chris Sorrows
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 136 Answers
Chris Sorrows
Expert
Level 2:
Cheetah:
Answers
136
Questions
0
Helped
41412
Points
396
Http://support.xbox.com/support/en/us/xbox360/hardware/default.aspx
3 Related Answers
Anonymous
  • 57 Answers
  • Posted on Apr 10, 2007
SOURCE: xbox 360 not turning on, just red flash
It seems the power supply of your console has gone bad. Kindly have a local cartified technician check your Xbox ASAP.
A
Anonymous
  • Posted on Dec 30, 2007
SOURCE: The xbox 360 red light flash
turn it on and wrap it with 2 towels for 20 minutes(the idea is to overheat it), then unrap the towels and let it cool down for 20 minutes. Then, walla it works.
A
Anonymous
  • Posted on Jul 22, 2008
SOURCE: fix xbox 360
give the customer support a call!
When i turn my xbox 360 on it starts running hard then the controller lights on the device start flashing red.
Four lights around the power button flash red on your Xbox 360 console. Four flashing lights indicates that the console does not detect an audio/video (AV) cable.
Note Four flashing red lights will not appear on consoles that have both an AV port and an HDMI port.
Solution
http://support.microsoft.com/kb/906652
I have got two flashing green and red lights on my
Either something freaky is happening to your Xbox, or you have the "red ring of death" which mean you'll have to take it to get repaired.
2answers
Red light flashing and will not work.
if that happens make sure all the connections in the back of your xbox 360 are connected and if it is still flashing red its probably the red ring of death and thats were three rings are flashing red so if its like that your going to have to send your xbxo 360 into microsoft
Two red and green lights around the on button?
http://ezinearticles.com/?What-Do-Xbox-360-Red-and-Green-Lights-Mean?&id=1981493
1helpful
2answers
Four flashing red lights, xbox worked fine lastnight
Doesn't really have to do with hdmi. They call it the red ring of death, I've had it happen to me 4 times. It's a problem that happens to almost everyone. Call 1-800-4my-xbox, "I think that's right" and tell them your problem, they fix it for free, and give the address to send your xbox to and send you a new one. Just call and they will go over everything with you.
Xbox red green flashing lights
r they all red or only certain ones the most common thing to check first are the av cables/hdmi cable from the xbox to the tv.. if they are loose on the xbox it will show the red ring in a sequence make sure their tight...if this does not fix it YOU HAVE THE RED RING OF DEATH its either overheated or you have a bad disk drive or something internal....you will need to call microsoft
2answers
Xbobx 360 3 red lights
3 Red lights problem is a drawback of Microsoft Xbox 360
Check out the blog post at http://www.fix-xbox360.info/2008/08/23/xbox-360-red-light-fix/ to know more information on fixing your xbox
2answers
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
1helpful
3answers
Xbox 360 red lights
2 red lights flashing is'nt too bad of a deal. just reposition your xbox 360 to a place where more airflow can get to it. plus, dont have anything that gives off heat near the xbox 360, thats vary important to give it room for cool air. it worked for me
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
