That's too bad that your RV fridge isn't working when it's on electrical. My own was hit by a deer as we drove, and it dented one of the axles. We need to find a mobile RV repair who can come and help us. You might want to find someone like this too. http://fastmobilervrepair.com/That's too bad that your RV fridge isn't working when it's on electrical. My own was hit by a deer as we drove, and it dented one of the axles. We need to find a mobile RV repair who can come and help us. You might want to find someone like this too. http://fastmobilervrepair.com/
You can't post conmments that contain an email address.
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced.
Sounds like your ignition board is not working.
Aftermarket ones have a common automotive fuse.
Have a look at the following on line so you know what you are looking at in your unit.
Dinosaur electronice makes a UIB ( universal ignition board ) that will fit just about any fridge.
about $100 online. $250 where I tried to buy one at a rv place.
u need to open the thermister up its located on the back on the fin also check to make sure u are getting full 12 volts to the fridge check the voltage at the fuse
Sir,
To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant.
I suggest you to contact the service authority.
are you running gas to oper the frig in the rv or electricty if only using the heating element for the frig RV STYLE ONLY maybe starting to make and break causing intermittent cooling or not enough cooling in frig but at all thing concerned try to increase you temp setting higher if you have that option
in your refridgerator there is an internal thermostat on the cooling fan u can move up or down it should be placed on the last finn to the right looking at the fridge
thanks
cruz
cruz's mobile rv repair
