Microwave Ovens Logo
Posted on Aug 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model 565.66400, still runs when door is opened?
Anonymous
Level 2:
Sniper:
  • Expert 70 Answers
  • Posted on Aug 16, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
70
Questions
0
Helped
28207
Points
176
If unit runs with door open then one of the door switch is stuck closed.there are 2 door switches and they could be assesed by removing the control panel.disconnect wires from top and bottom switches and chkf for continuity.they should be normaly open when the door is open and closed when door is closed.one of them will closed even when door is open.replace that bad one.
My GE Microwave Convection Oven model JE 1390WV runs whenever the door is open. It microwaves on the normal settings, but when the door is opened it turns on and runs.
DO NOT USE IT!!!! THERE IS A SWITCH IN THE DOOR LATCH THAT NEEDS TO BE REPLACED.
AGAIN DO NOT USE IT!!!! IF ITS RUNNING WITH THE DOOR OPEN YOU COULD DO SERIOUS DAMAGE TO YOUR HAND OR ARM IF IT IS NEAR THE OPEN DOOR
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
My GE Spacemaker (HVM1540) will not turn off. Often when we use it and open the door to get food out, then we reclose the door and it continues to run. Even after hitting Clear/Off it continues to run...
Ok I have the same model and mine was doing the same thing. Apparently this model has a reputation of problems with the control board. I played with mine for hours and here's what finally worked: unplug the unit (or shut off the breaker--whichever's easier for you), take a dry cloth and wipe the door latches and control board clean of any residue. Then with the door still open, gently jiggle the control board by firmly grasping with your hand. Power up your unit again. This worked for me. The control board is really fussy and should be clean and free of any dust or residue. I notice this happens again when it gets dirty so I repeat the process and it's been working.....so far!!!
Cooling Fan stays on until the door is open
May be a sensor or thermostat for the fan thats faulty therefore it runs all the time.
2answers
Microwave runs when door is opened
Dont run it with the door open....The microwave are not good for you...You have an interlock switch problem...They can be adjusted...Sounds like one is stuck or bad in the closed position...Again do not run with door open......
GE Microwave Model JE1640WA runs when the door is open only
You probably have a loose or broken door switch mount or the door may be slightly misaligned.
See:
http://www.microwavedisplay.com/safety.txt
and
http://www.microwavedisplay.com/disassembly.txt
and
http://www.microwavedisplay.com/doorsw.txt
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
1helpful
Microwave runs when door open
This is probably a a bad door switch or door switch mount. Chances are only the fan and light are running when you open it, but better safe than sorry. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure but not the only one. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. You can find these files by searching at Yahoo.com (not Google) for this: microwave display safety.txt If you still have a problem, please write back with more detail. Be safe!
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
