If you lift the top of the machine and look at the control panel ( you might have to pul the front too) you will see a fuse in the front.
Most likely that one is broken
Hello, the boiler has two shields or breakers. Each has two feet between which there is a button. Something has happened and one button has leaped up and turned off. You have to press it and it will click lightly and make a chain and the machine will light up.
Make sure that both the tray and dump box are placed correctly- otherwise the machine will not start. Both have a switch and when that switches are not engaged, the machine will not turn on.
dont worry if it was working good before the clean up the brew group is not install all the way in remove it push it in untill you here a click the brew group is not all the way in and doesnt push the on switch when you push it in wiggle it
