Master
- Posted on Aug 18, 2009
Re: I have a 1987 ford bronco and will not start replaced...
Check the wires to the module,im not too sure what color wire to check,its been 5 years since i worked on that issue on a ford truck,but i think its a white wire with a black stripe-basically power from the key-also check the fusible links by the starter solenoid on the inside fender
No I am not getting spark it has a new pick up coil and a ignition control modual and coil are both of of a truck that was using them when I put them on mine to see if that was my problem Could it be my crank sensor?
does it have spark? does the distributor rotor turn?
