Question about Porter Cable Garden
Hot water coming out of a cold water pressure washer
I have a Porter cable pressure washer powered by kohler that for some reason is making the water come out of the wand warm. What could be causing this?
Posted by cook_travis8 on
  • Anonymous Mar 31, 2014
    how to remove the top of the motor
    oil comeing from top of motor
Anonymous
  • 174 Answers
This sounds like a heat transfer problem
You should check that the oil reservoir for the pump has oil in it. It sounds like it may be low. Also, if it is a gas model, the engine oil may be low.
Remember the pump oil reservoir should be only 1/3 to 1/2 full of non-detergent oil.
Posted on Aug 11, 2009
No hot water on New Kohler touch less kitchen faucet. Had plenty with old faucet I'm replacing.
You need to make sure that the small flex line going to the water supply is not kinked than if that dont work make sure theres no trash in the cartridge
Oct 05, 2016 | Kohler Plumbing
Hot water comes before cold water for Kohler Mixer Pressure Kit
If this is a tub/ shower valve, you installed the cart. upside down. Reversing it should solve the problem. You might have put it in according to instructions but the hot and cold might have been reversed when the valve was plumbed in.
May 03, 2012 | Kohler Plumbing
Engine manual for the Porter Cable pcv 2250 pressure washer
If you need an engine manual, then look up the manual on the engine manufacturer's web site. eg Briggs & Stratton, Honda, Techumseh. Porter Cable manual would just have cart and pump info.
Jul 23, 2010 | Porter Cable Cable Commercial Pressure...
I have a porter cable 4000 psi 4gpm...what is the max hot water temp I can use...pump is AR RKV4g40
There is an LP Hot Box you can purchase to make your pressure washer a hot wash system:
http://www.scpressurewashing.com/SCPW%20Sales.html
Top line of products center.... That is about as hot as it gets. And they work well!
Thanks for using FixYa!
Kelly
Mar 08, 2010 | Garden
No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Oct 07, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Porter Cable pcv2250 pressure washer shooting water out of siphon
non return valve on syphon injector on high pressure outlet stuck or 'o' ring worn. remove barb should be a spring and ball bearing in there.
it may be that the spring has broken too.
new non return valves are available.
Jul 06, 2009 | Porter Cable Cable Commercial Pressure...
Pressure problem with Kohler shower faucet??
Hi pglaw,
My best guess is the supply valve for the hot side isn't open all the way. This valve is right on the valve and is accessed by taking off the front cover plate. This would still allow the pressure balancing valve to let water through but then you would have a small flow on the hot side.
If this isn't it then then cartridge is bad.
Please rate this response and good Luck,, phil
Dec 30, 2008 | Kohler K-T10335-4-CP Lyntier Rite-temp...
No water coming out of my Kohler Forte R10275-4-BN shower valve
This is a pressure balancing valve that needs both cold and hot water pressure to operated. It is an anti-scald safety operation.
Good Luck, Phil
Dec 25, 2008 | Plumbing
Washer issues
So...is there no cold water coming in?
If so, turn off the cold water and disconnect the hose from the washer, then ( with the hose in the sink or washer) turn on the water at the supply and verify normal water pressure. Check the screens in the inlet valves where the hose connects to the washer, make sure there is no gunk blocking water flow. Finally, if this doesn't help....you can either replace the water valve, or if you want to get intense, you can remove the washer cabinet and check with an electrical meter for voltage at the cold water wire harness. If you don't have 120v at the valve with the washer timer turned to the wash position and turned on, (where it would normally fill) you need to replace the timer, which supplies voltage to the water valves. Hope that helps...post again if you have more info or q's.
Jan 17, 2008 | Washing Machines
Garden Logo
126 people viewed this question
Top Porter Cable Garden Experts
JOHN LAPIER
ray gallant
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
