Question about Samsung HL-P6163W 61" TV
Can't turn on t
I have a samsung 61" tv and It will not turn on. When you turn it on there is a high pitched loud whirling sound coming from the back. You have to unplug to shut tv off.
Posted by redesx4 on
Anonymous
Check the color wheel because that's usually the culprit when the set starts making that whirling sound.
Posted on Sep 09, 2009
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Tv samsung hls4266w all light are blinking replace the blud small fan and large fan running
Sounds like a bad color wheel----remove lamp---the wheel faces it--look for missing pieces or the wheel shattered---these are known for the wheel making a loud high pitched sound or even a grinding sound if the wheel shatters.
if wheel bad You Tube has video instructions for replacing it---seen several people able to do this themselves in about a hour. Google the model number to ("color wheel") to locate a replacement on the internet.10_24_2012_4_08_47_pm.jpg
Oct 23, 2012 | Samsung 61" Slim-Depth DLP HDTV
Tv started making loud whirling noise, then picture turned greenish and whirling noise continued. I think the color wheel motor went out, is it something i can fix on my own?
Yes ,you can fix it yourself just be sure that when you start you tape and Label everything you disconnect so you reconnect back correctly. Encompass Parts Distribtion will List Parts/Prices at there website.1-800-638-3328
Problem is Color Wheel! PN# BP96-00674A
Samsung Parts 1-800-627-4368
Oct 16, 2010 | Samsung HL-R6167W 61" HDTV
Our tv is Samsung DLP HL-P4663W 46 in. Rear Projection HDTV-Ready Television After having our TV on for about 45 minutes it starts to make this hissing sound which starts low and gets louder and louder,...
hello
This looks like a colorwheel symptom, does the sound is like a mechanical sound? high pitch sound? winding, whirling or screeching noise ? well if this is the color wheel, what i think it is, it seems that it is not working properly when this happens the DMD board recognizes that it is not spinning at the correct RPM and turns off the Tv for sercurity reasons, so if you want to replace this yourself what i recommend you to do is to open the back of the Tv and search for the colorwheel it can have missing parts or it could be shattered or it could not spin correcty, hope this info. can help you.
Jun 14, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
When i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Buzzing sound
The sound is a result of the faulty CRT base, and you will have to replace the base socket. Make sure you by the exact same type of base, and if you are not a techie, get a qualified technician, this is not a costly problem.
Jan 17, 2008 | Samsung HL-P6163W 61" TV
Weird noise over everything
According to the Samsung website: "The high pitched sound you hear is probably coming from the flyback transformer. The flyback transformer converts the relatively low voltage electricity that comes from the outlet in your home to the high voltage electricity needed to drive the cathode ray tube in your TV. It is not unusual for a flyback transformer to buzz softly when it operates. However, if the sound is loud and high pitched, it probably means the transformer is failing. To eliminate the sound, you will have to get your TV serviced."
Nov 08, 2007 | Samsung SlimFit TX-S2783 TV
High Pitch Sound From Samsung TXN3071WHF 30" TV
I think its the flyback and its starting to leak. this is a component responsible for the high voltage of your tv set. always observe safety in dealing with this. Have it check by a qualified technician. Good luck!
Feb 25, 2007 | Samsung TXN3071WHF 30" TV
Samsung HL-P6163W 61" TV Logo
220 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
