Question about Frigidaire GLTF1670A Front Load Washer
LOUD CLANGING EXCEESIVE NOISE DURING SPIN CYCLE.
LOUD CLANGING, EXCEESIVE LOUD NOISE DURING SPIN CYCLE. INSIDE TUB CAN BE MOVED FREELY FORWARD/BACKWARD AND SIDE TO SIDE. WATER SPINS OUT OK. CLOTHES ARE NOT SOAKING WET. WHAT SHOULD WE BE LOOKING FOR?
Posted by mom4god22 on
Anonymous
  • 998 Answers
I would think the bearing
Posted on Aug 10, 2009
  • Anonymous Aug 10, 2009
    i would think the bearing
  • lisa Sep 21, 2013
    how do you fix the bearing without calling a sevice man?
During spin cycle the washer makes a loud thumping noise. Not a clanging/sharp noise. When I manually turn drum it sounds like something is loose inside. Like a ball may sound inside drum as it turns.
Is it a front loader? You may have something stuck between the tubs or it may be a broken "paddle" One of the plastic baffles that move the clothes around in the tub. they should all be tightly against the tub.
May 26, 2015 | Washing Machines
Washer is a Samsung WWF337AAW-XAC. Just prior to the spin cycle we hear a rattling or grating noise and then it rattles throughout the spin cycle. It will sometimes rattle at the end of the rinse cycle but...
hi Rick.
Reasons a washer will make noise during spin mode:
1. Main tub bearing faulty
2. Main drive pulley
3. Motor coupling worn
4. Bad clutch
5. Worn out drive belt
6. Clogged or damaged drain pump
7. Transmission is worn out
8. Shock absorber (front loader washers)
9. Springs or dampening straps (top load washers)
10. Agitator directional cogs aka "agitator dogs" (top load washers
When the washer spins, it rides on a bearing that allows the tub to move freely with zero resistance. If this bearing is worn out, a loud noise will be heard when the washer spins. A good way to tell if your washer problem is the main tub bearing will be that the washer noise will get worse or louder as time goes on. This means the bearing is becoming more worn out and close to complete failure. The bearing in your washing machine is a circular metal object that has many small little metal balls inside. These small metal balls inside the bearing sit in a track and move when the washer is spinning. If the tub bearing begins to wear out, usually the small metal balls inside can fall out one by one causing the noise you hear. (If your washing machine is a front load washer, open the door and turn the drum by hand. If you hear a rubbing sound or the drum spins uneven, then the main tub bearing is most likely bad and needs replaced.)
Washing machine tub bearing
Washer has noise during spin cycle
The bearing may also be without lubrication. If the sound you hear is more of a squeaking noise than a grinding noise, it may mean the bearing needs to be lubricated with a mechanical grease. If the sound is more of a grinding noise, then this usually means the bearing is falling apart and will need to be replaced ASAP. If you suspect your washers main tub bearing is worn out, the repair process is one of the most difficult to perform yourself. A worn bearing can also damage the tub of the washer. This means the tub (inner or outer) may need to be replaced also.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to your washer) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose. To find out if the drive pulley is causing the noise, you will need to take the washer apart and inspect the pulley for signs of damage.
WASHER MOTOR PULLEY
The motor coupling could also be the cause of the loud noise. The motor coupling in your washer connects the washers transmission to the motor. It is made of plastic and built to break if the washer gets overloaded. This is so the motor and the transmission do not become damaged. The motor coupling is an easier repair and can be done by most people.
Washer Washing Machine Motor Drive Coupling Coupler
The clutch in a washing machine connects the inner wash tub to the transmission. The clutch lets the washer get to the proper spin RPM in a gradual way. If the clutch is worn it can make noise when the washer is spinning. A bad clutch needs to be removed and replaced to stop the noise.
Washing Machine Clutch
The belt in your washer can become worn and cause noise while spinning. If worn out, replace the belt. Replacing the drive belt on a washing machine is an easy task and can be ordered online for less.
Washing machine belt
The drain pump in your washer that drains the water out could be clogged or damaged. While in spin mode, your washer may drain out the water by using the drain pump. If the loud noise only happens at certain intervals during the spin cycle, it may be the drain pump. Usually this can be fixed by simply removing the drain pump and removing any debris that may be clogging it up causing the noise.
Drain Pump for Washing Machine
The next part of your washer that can be causing a loud noise is the transmission. If the transmission is bad, usually the cost to fix this outweighs the cost of a new washer.
If you have a front loading washing machine, they all have shock absorbers. The shock absorbers are used to center the tub movement while in the spin cycle. These shock absorbers are connected from the washer frame to the outer tub. If the shock absorbers in your front loader become weak the washer will make a loud banging sound during the spinning cycle.
Shock Absorber for washing machine
Top load washers usually have springs or dampening straps holding the tub centered. If a spring or strap falls off or becomes weak, a loud noise will be heard in spin mode. Simply replace the strap, spring, or springs to remedy this issue.
Washing machine suspension springs
Agitator directional cogs are used to operate the upper part of dual action agitators (Top load washers). They engage the cogs on the inner area of the agitator as it turns in one direction. They release when the agitator reverses its direction. This lets the top part of the agitator to ratchet in only one direction. The bottom part will agitate in both directions. The cogs are made of plastic and wear out with regular use. They will start slipping and make a grinding noise. Another way to be sure that this part is bad is if you notice the top portion of the agitator does not move in a smooth motion. Removing the top half of the agitator to see if the cogs are worn out.
Dec 08, 2017 | Washing Machines
Maytag Neptuen Washer makes loud noise when spinning. Sounds like an airplane taking off.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.Get the spin bearing and motor checked.Replace the faulty. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Maytag Neptune Washer
Loud noise during spin cycle even when I rotate manually - loose
ok, from the sound of things you're not going to like me any better when i get done than you did previously.. :)
if you can move the clothes tub/basket (stainless steel with lots of holes in it) not only around in a circle, but forward and backwards, and i assume diagonally kinda/sorta also within the constrains of the outer plastic tub/shell u gots big problems!!
within the plastic outer shell that keeps the water in containment, and houses/contains the bearing and seal assembly, would normally rotate a 3 armed spindle to which that stainless clothes basket is attached, those attachment points were prone to fail!!! especially if you live where you have acidic water which attacks the pot metal spindle assembly within 2 or 3 years, sometimes a little longer but usually just out of "warranty" unfortunately. now be warned or happy depending on how your warranty is worded that some of those "electrolux/frigidaire" manufactured kenmore appliances came with a 10 year "part" warranty on that same stainless steel clothes basket, and if that has defected and destroyed the bearings within that rear tub half then sears in their infinite wisdom should and will "when pressured" replace them both as one led to the destruction of the other. the labor to change them would fall on your shoulders and i'm not sure what they are charging for that level of repair now.
if u had to buy those parts you are talking about approximately $170 for the rear tub half w/bearing, and $200 for the inner stainles steel basket..
if you've never changed one of these before plan on around 5 hours, 2 bandaids, and lots of patience as the bolts that hold the tub together are only available from the front yet you'll be doing most of your wiggling from the rear.. save the foam blocks that the tub half come with for shims/spacers to hold the front tub half up with once u remove the shocks and springs ;)
have fun, and best of luck to ya..
May 24, 2010 | Kenmore 43042 Front Load Washer
Whirlpool cabrio loud noise during spin cycle
The inner bearing will be faulty kindly replace the inner bearings as well as water seal before that kindly check whether the drum is freely moving with out any shaking If you find any shaking means you are suppose to change the drum only
May 15, 2010 | Washing Machines
Front load machine will not spin all the water out of the cloths and it is making a noise during the spining cycle.
Hello Friend,
The problem you described suggests that the spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle, as said by you. This would require to call a qualified appliance repair technician.
Check this and do get back to us for any further assistance.
Thanks for using FixYa....!!!!
Mar 05, 2010 | Frigidaire Washing Machines
Kenmore warsher, Model num 110.14202300, not drain or spin
The clothes too wet after spin cycle tells me that the water ump is functioning. If it wasn't, there would still be lots of water in the machine when the cycle ended. These Kenmores have the water pump mounted on one side of the electric drive motor and the transmission, drive shaft, and agitator on the other side. The transmission is fastened to the motor by a "coupler", a three piece assy that often breaks. This common failure allows the machine to complete a cycle, however, because of the broken coupler, there is no drive to the tub and no spin or agitate. The clothes seem wet because the spin motion is supposed to provide the force to extract the excess moisture. Leave the lid open and verify that there is no agitate or spin.(During spin cycle use a pen to press down on the safety interlock, a small opening on the the of the machine, toollow the unit to spin with the lid open). If you verify this, flip the machine over and locate the coulper on one side of the motor. One side will be cracked along the shaft. Sears parts stores carry the coupler in stock. ($18.50) Hope this helps.
Jan 18, 2010 | Kenmore 22422 Top Load Washer
Tub bottoms out when filling with water. Don't think it is the suspension rods.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Jul 31, 2009 | Washing Machines
Loud noise during spin cycle Kenmore Elite model 110.20952991
check balancing
look in side the lid small clothes some how may fix anywhere inside
Jul 23, 2009 | Washing Machines
Frigidaire GLTF1670A Front Load Washer Logo
2,304 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Marvin
Marvin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
