Question about Lexar MDA256-100 MP3 Player
My mp3 player tells me incorrect format reformat the player?????
Posted by lowranceangi on
Anonymous
Go to lexar.com and click on live support via chat. Excellent support from service agent at Lexar. Emailed me the firmware upgrade link and instructions within 10 minutes. The upgrade should be done via Windows XP machine. Vista not yet supported. That should have been in the instructions (e-mail). Anyways great support from Lexar.
Posted on Oct 19, 2009
Anonymous
  • 63 Answers
Either it is faulty or u should reformat it. it should be easy. you can find instructions on the internet.
Posted on Aug 10, 2009
5 Related Answers
Anonymous
SOURCE: reformat
Plug the mp3 into your computer, open your "my computer" folder and click on the drive your mp3 is plugged into. right click the mp3 icon and click reformat. should fix it but it will get rid of anything on the mp3
Posted on Jan 16, 2008
CasaLaDay
SOURCE: reformating
I have the same thing man, i dont know where my cd is for it.
Posted on Feb 21, 2008
Anonymous
  • 9 Answers
SOURCE: Lexar MP3 Player 100
Attach MP31.gif to computer1.gif.
Open explorer and right click the MP3 drive letter.
Choose FORMAT
Next window choose FAT32 and Quick as the options.
Posted on Mar 21, 2008
Anonymous
SOURCE: Incorrect Format Please Reformat the Player
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
  1. Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.)
  2. Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible.
  3. Download the correct Firmware
    1. Click here to download the ILO 116 Firmware
  4. Click Open to initiate the download
  5. Double click on the ILO or Siren folder icon. There will be 14 icons.
  6. There will be a Setup icon that looks like a box with a blue line on it; please double click on this.
  7. Then click Run - this will open the Install Wizard.
  8. The Install Wizard has the instructions on the screen as you go through it.
  9. Once the firmware has installed, please click the Start menu, then Programs.
  10. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware.
It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
Posted on May 20, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: how do i reformat my ilo mp3
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Posted on May 26, 2008
Pleazz help my mp3 is my life
-Tha Mp3 Doctor
May 17, 2008 | iLO (2 GB) MP3 Player
-Tha Mp3 Doctor
Apr 24, 2008 | iLO MP3 Player
Reformating
Reformat in Windows Media Player instead.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Apr 06, 2008 | Siren Edge MP3 Player
Incorrect format
The songs that you loaded onto the player are not in the correct format - iTunes, DRM-encrypt. WMA are not allowed, for instance. Convert everything to mp3 format. It is asking you to reformat the player because it wants you to delete the wrong-formatted songs off the player. I would check your user manual to find the best way to reformat.
In general, though, there are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
-Tha Mp3 Doctor
Mar 03, 2008 | AIGO F008 MP3 Player
Incorrect format; reformat the player
Choose FORMAT
Jan 11, 2008 | Lexar JumpDrive MP3 Player
Incorrect format
mine to same problem
Dec 27, 2007 | Lexar JumpDrive MP3 Player
Reformat the player
Choose FORMAT
Sep 27, 2007 | Lexar JumpDrive MP3 Player
Won't format
You can try a factory reset if it's available on the player or try the manufacturers web site as they may well have a formatting programme online and downloadable.
Jan 29, 2007 | iLO (2 GB) MP3 Player
My ilo tells me to reformat it.!? How do I do that?!
Formatting is pretty easy. Go to a computer, plug it in, then right click and it should have an option to format. Unfortunatly, it will delete any saved information on it. Hope it Works
Jan 09, 2007 | iLO (2 GB) MP3 Player
Formatting MP3 Player??
how do you fix it using the stmp3rec.zip and the install program?
May 29, 2006 | LG MF-FE502 MP3 Player
Lexar MDA256-100  MP3 Player Logo
Top Lexar Audio Players & Recorders Experts
Are you a Lexar Audio Player and Recorder Expert? Answer questions, earn points and help others
