Question about Photography
SOURCE: Vizio VX32L The screen goes white,no response from buttons
G'Day!
Unfortunately, what you're describing is a repair
issue. You won't be able to address the problem with troubleshooting.
There is a part inside the TV that needs to be replaced. If you're
under warranty, this will cost you nothing. If you're not under
warranty the cost will likely be a minimum of $200 parts and labor.
However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
Posted on Jul 28, 2009
SOURCE: blank white screen
Did you try gently pushing the tiny RESET, with a narrow pointed object like a paperclip on the back side ?
RESET pin hole back side ( 8 ) .
Manual for the MP610 in pdf format:
http://www.cobyusa.com/files/manuals/MP610_MN.pdf
Posted on Jun 01, 2010
SOURCE: GE photo phone. Phone works. Photo frame was blank. 0 pictures
Remove the battery, unplug the phone, wait 48 hours. That might fix it. Or just get a new phone, these are poor.
Posted on Apr 15, 2011
SOURCE: Machine stopped at rince cycle.
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Apr 29, 2011
SOURCE: My 3g screen is not responsive after changing the screen/digitizer/frame.
I would verify that all of the proper connections are in place. Here's a video for clarification:http://www.youtube.com/watch?v=4mboB8p-sdw
Posted on Dec 14, 2011
Apr 06, 2012 | HTC Touch Dual Slider Smartphone
Nov 21, 2010 | SmartParts SP15MW (092566981886) Digital...
Oct 18, 2010 | iiyama ProLite E481S-B 19" LCD Monitor
Jun 01, 2010 | Coby MP-610 MP3 Player
Apr 05, 2010 | SmartParts SP104MW Digital Picture Frame
Dec 31, 2009 | Kodak EasyShare V803 Digital Camera
Oct 25, 2009 | General Electric 27956FE1 Cordless Phone
Jun 04, 2009 | Philips GOGEAR SA6045 MP3 Player
162 people viewed this question
