Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: Device not ready message
I had the same problem trying to transfer pics from my camera. The error message is "The Device is not Ready." I got mad when I read the "solution" from the "plumber" that said to read the directions. DUH!. Now for the real solution... and reading the directions won't help. Your PC is trying to find the camera connected to a specific drive. In my case it was the "E" drive which was already in use, mapped to a shared drive. Once I disconnected that drive it fixed my problem. To disconnect, highlight the drive, go to Tools and Disconnect Network Drive. Reboot the PC and plug the camera in before booting back up. (If you have hardware connected to the drive, right mouse click on the drive and eject.)
SOURCE: drivers for fe 210
SOURCE: how to connect my olympus fe-360 cam. to laptop as webcam
Unfortunately this camera is not capable to be used as a webcam. It is only to be connected to the computer when you want to download images from the memory card to the computer.
SOURCE: How do you transfer pictures from camera Olympus FE-20 to compute
one of the manual must help you.... if it does dont forget to rate!!! http://www.olympusamerica.com/files/autoUSB.pdf
http://www.olympusamerica.com/files/FE-360_X-875_C-570_FE-20_X-15_C-25_Instruction_Manual_EN.pdf
SOURCE: my olympus fe 210 has the lcd screen broken, I would like to fix it by myself, how to replace it?
Hello Fabio,
You can find the replacement LCD screen for Olympus FE210 here:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/en_GB/?ObjectPath=/Shops/160419/Categories/Olympus
