SOURCE: no tape icon when the tape is installed
Have you push down the cassette tray before closing the lid?
SOURCE: canon xl1
I had the exact same problem; my tape icon was flashing red with a line through it and the recorder would not record, no matter how hard I begged it to. After a full day of frustration, I called the videographer who had used it previously. There is a little trick.
1. Open the exterior tape door with the "Eject" button.
2. Wait, dont touch the tape. The little metal encasement will pop over and open within a few seconds.
3. To properly put the tape in, insert tape, push the little metal door that sais "Push this first".
4. Then push the exterior door closed.
Voila! Thats all there is to it!
SOURCE: Bars across picture when replaying tapes.
The tapes were recorded in LP mode and the replay is set to SP mode. Switch from "EASY" to "P" and replay and you should be OK
SOURCE: It appears as though the
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician. My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs. If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
SOURCE: Recorded something last night.
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly, a defective clutch in the take-up spool or a faulty rotary mode switch. This will require disassembling the camera to repair and can be done fairly inexpensively. However, it's not really a user serviceable problem and should be repaired by a qualified service technician. My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs. If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
