Question about Furniture
How do I remove too much linseed oil from rattin?
It is very sticky on the furniture. Too much
Posted by Riana DeKock on
Elsifer
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
I would use mineral spirits.
Posted on Sep 04, 2019
Can I use a mixture of raw linseed oil and turpentyne on Quarry tiles?
Depends on what your final purpose is.
If it's to preserve them (i.e. waterproof them) you might want to try boiled linseed oil instead. It's more persistent although it takes a bit of time to penetrate fully.
Dec 19, 2017 | Garden
How do I remove Linseed oil over spray from off my car wind shield ?
Immediately, keep the car out of the sun. Linseed oil will harden in the sun and heat. Wash the screen using cotton cloth with a drop of white spirit and then methylated spirits.Clean the wiper blades the same way. Dry and polish the screen with a clean dry cloth. The same for the wiper blades. Repeat if necessary. Dont soak anything. These solvents are flammable.
Feb 14, 2015 | 2011 Ford Escape - All Escape models -...
How do i remove sticky tape residue from wooden furniture
A commercial product such as "Goo Gone" works well. You can find this at your local hardware store or Walmart for example.
http://www.walmart.ca/en/ip/goo-gone-16-oz/6000093378251
Sep 18, 2014 | Furniture
How to remove linseed oil
scrape of as much as you can with a plastic scraper to min any damage. The use paint thineer to clean off the rest.
Jul 09, 2014 | Klean-Strip Klean Strip Boiled Linseed Oil...
Try washing it off with Turpentine
May 17, 2014 | Office Equipment & Supplies
Can i use linseed oil on my granite counters
you should not use linseed oil or any other oil on granite countertops unless the desired look is a darker stone. The oil may not penetrate depending on the color and density. Linseed oils are generally only for soapstone.
Apr 28, 2014 | Building Materials
My front wheel sticks
The most common reason for this is a build up of dirt and debris. Remove it from the pushchair and clean it regularly to prevent this from happening. Clean with furniture polish or dry Teflon spray (found in the laundry aisle of larger supermarkets) Do not clean with oil based lubricants as these will leave a sticky residue and attract more dirt and debris and cause additional issues.
Feb 03, 2012 | Quinny Buzz Three Wheel Stroller
Hi, I want to use my H.P Deskjet 520 (mono-printer) to print standard paper with a spirit-based and colourless solution that contains a percentage of 'linseed oil'. However the linseed oil is clogging the...
I'm not sure why you need to use a solution w/ linseed oil. But the cartridge is not designed for oil based printing. It's original use is for water based dye inks. So any oil based or oil mixed product will eventually clog the jet sooner or later. Since you are printing w/ this I can only guess you are planning to coat the surface of the paper. There is another chemical that might be available w/ one of your ink manufacturers that is used to refill some Epson cartridges that they use to do a kind of gloss coating on paper. Using a printer to spot coat an area is possible. But most people just roller brush the whole sheet. It's faster than using the inkjet printer.
Jul 24, 2008 | Office Equipment & Supplies
Furniture Logo
188 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
