Question about JVC HD-56FN97 56" Television
The lamp is located at the back side of the set. Usually on one of the side. Step 1: It should only take a philllips or flat blad screw driver to take the customer access panel off. Step 2: There wlll be screws holding the lamp housing in place either a phillips or flatbladed screw drvier. Step 3: Double check to see if you have all of the screw removed, then pull the lamp assembly out. Step 4: Then put the new lamp back into the assembly. Repeat the steps in backwards order and you are back in business. A word advice if you call a serviceman out they will charge. because they are suppose to be customer serviceable.
Posted on Aug 10, 2009
Part# ts-cl110uaa. You're welcome....meder's Tv
Posted on May 20, 2010
This TV actually has it to left side (front view) at the bottom
Posted on Feb 01, 2010
