Re: MY pro-94 said on the screen lu,red or something like...
Could the display be saying "wired"? This is what it shows when it is in cloning or programming mode. If it is showing this and there is no programming or cloning cable attached, check the programming jack to see if it is damaged.
I'm guessing that the display shows "wired" and not "luired." This mode, along with the code, is supposed to clear when the computer programming cable is disconnected. If you don't have a cable connected, your only option is to RESET the scanner to its original factory settings. Just a caution: resetting the scanner will erase/delete all programmed information -- you will have to reprogram all of the data that you've previously entered. To RESET the PRO-94:
1. Turn the scanner OFF. 2. While holding down the 2 and 9 keys, power the scanner ON. The message "CLEAR" will flash for about 5 seconds while the scanner resets.
NOTE: Do not turn the scanner OFF until "CLEAR" stops flashing.
- Power the unit OFF - Press and hold the 2 and 9 keys while you power the unit ON - "CLEAR" will flash on the display for about 5 seconds as the scanner clears and resets itself. - Do not power the unit OFF until the CLEAR message stops flashing
NOTE: This procedure will clear (erase) all data that you have programmed into it, so be prepared to reprogram everything.
Need the manual for your PRO-94? You can download and print it, at no cost, here:
Getting "stuck" indicates that the scanner may need to be reset to restore proper operation. This is a fairly drastic step that will erase ALL information that you've programmed into the scanner, but it's about the only fix. To reset the PRO-94:
- Turn the scanner OFF
- While holding down the 2 and 9 keys, power the scanner ON.
- CLEAR will flash for about 5 seconds as the scanners clears its memory and restores factory settings. Do not turn the scanner OFF or press any keys until the CLEAR message stops flashing.
Need the manual for your scanner? You can download/print it here:
No telling what he did, but if you've tried deleting his entries and the scanner is still locked up, you'll need to reset it. This procedure will clear all the information you have have stored in the scanner. 1. Turn the scanner OFF. 2. While holding down the 2 and 9 keys, turn the scanner ON. CLEAR will flash for about 5 seconds while the scanner clears its memory. NOTE: Do not turn the scanner OFF until CLEAR stops flashing.
Need the operating manual for your scanner? You can download;/print it here:
A RESET may clear the problem, but it will also erase all frequencies and data that you've programmed into the scanner. To RESET the PRO-94, - Turn the scanner OFF - While holding the 2 and 9 keys down, turn the scanner ON. CLEAR will flash for about 5 seconds as the scanner clears its memory and restores factory settings. Do NOT turn the scanner OFF until CLEAR stops flashing.
press the "prog" key followed by the "Trunk" key then the number "1" key. Press the "down arrow" key until you see the initials Ed on the screen Press the "E" key. Enter the frequencies (including the decimals) you must press the E key and the Prog key after each frequency, after you finish entering your frequencies, press the scan key.
If you need to clear your scanner, turn it off, press and hold down the number 2 and number 9 keys, while holding them down turn the scanner back on, "clear" should start flashing on the screen, once "clear" stops flashing you can enter the frequencies.
