This is indicitive of a driver failure or problem with either the hardware itself or a device conflict with another piece of hardware.
a quick check can be done by going to control panel, system, hardware, device manager.
If you see anything with exclamation marks start there if not then check that your hardware exists in the list
If its not in the list you will need to re-install the drivers / applications software for it.
Remember also that some usb hardware does not like switching to different usb ports which also requires re-install.
If you have it on a usb hub the ensure that the hub has its own power supply and is USB 2.0 not 1.0
Hi guys, i have same problem.,can u help me guys..every time i uninstall and i plug in my cam,ill wait just few minute b4 my computer can detect my usb cam and going to work, then in few minutes my cam not going to work again, showing this again "Sorry,you have no video capture hardware. Video Capture will not function properly." - pls help me guys. thanks
I had this problem with a Sweex webcam, because the drivers wouldn't install properly using the official installer. I got Windows (Windows XP) to install the files instead:
1. Uninstall any official software that came with the webcam
2. Plug the webcam in, and when the New Hardware Wizard pops up, tell it that you'll use Windows Update. However, on the next screen, tell it to browse in a specific location (advanced users).
3. Browse to the folder where the files are located. Choose the one for Windows XP, assuming that's what you're using.
4. Let it search, and if you need to confirm the certification, do that. Now the webcam should work - fingers crossed!
My pc is creat a problem in my webcam. error is "sorry, you have no video capture hardware". plz tell me a salution qucliy
SOURCE: webcam will not load divers
make sure that the Webcam is connected properly and is switched on>
then try and uninstall and reinstall the Webcam
