Question about Measuring Tools & Sensors
What is E297 error code in Sokkia 1x - Measuring Tools & Sensors
Posted by Bashiru Lawal on
2 Related Answers
Dale T
SOURCE: Sokkia PL 100 pipe laser showing error code
Hi I know it is 2 years too late but I thought I would write the solution for others
press the up the down and the on/off but all together after a few seconds CAL 3 will appear and the lser turns off.turn the laser back on again and it should be reset to 0.00 procent-you need to calibrate the laser now using the same method
hope this helps
Dale
Posted on Dec 06, 2011
vogesclive
Clive
  • 882 Answers
SOURCE: we have sokkia cx107 giving error code e880 as switch on instrument. please give solution
https://www.manualslib.com/manual/1199954/Sokkia-Cx-101.html
Posted on Dec 02, 2017
In Sokkia CX 101 Total Station Error E097 comes ....What is it means and how to solve that ???
CX series
www.sokkia.com.tw/download/??/CX_series_E-copy.pdf
Jan 1, 2012 - CX-105. CX-107. Compact X-ellence Station. CLASS 2 Laser Product ... Except where stated, "CX" means CX-101/102/103/105/107. • The CX ..... Ignoring this indication and making an operation error .... Make sure that moisture or dust particles do not come in contact with the inside .... detergent solution.
Mar 21, 2017 | Computers & Internet
The lcd displayed E190 error. i want to know the problem
The E 190 message means there is an error in the horizontal encoder. You need to contact the Sokkia service.
Apr 06, 2016 | Sokkia Set 610 Series Total Station Topcon...
E191 for total station, sokkia type, it does not observe horizontal and vertical angle & does not measuring
Sokkia total stations are repaired using Sokkia proprietary computer software. You need to return it to a Sokkia shop, no other shop will be able to corect this, not even Topcon (even though Topcon bought Sokkia).
Jul 29, 2015 | Sokkia CX-105, CX series, Total Station...
What is meant E024 error code of SET550X SOKKIA total station?
Hi Aung,
E024 is for F4 cal level error.
what this means is that one of the frequencies used in your distance measurement needs adjustment. This adjustment can normally be done as part of your annual service.
Not having it serviced for a long time is often the reason why these types of error will occur....
rgds, Paul
Jun 09, 2014 | Sokkia Set550x Total Station, Two Years...
Error e191 sokkia 1030r
Sokkia 1030r displays e191 in horizontal angle window
Jan 19, 2014 | Sokkia Set210 / Set310 / Set310 / Set510 /...
Error 6000
This is the error code printer Canon IP1200, IP1300, etc. light blink Indicator:
3x orange 1x Green = mechanical error
if you dont have any knowlegde about printers, better bring your printer to Canon service center.
4x orange 1x green = printer absorber full
reset your printer using software ressetter or try using manual reset. different printers have different manual reset.
5x orange 1x green = black cartridge/color cartridge error
can be chip error or connector is dirty.
7x orange 1x green = black cartridge/color cartridge error
8x orange 1x green = printer absorber full
12x - 17x orange 1x green = cartridge detection error
How to Reset waste ink counter Manually 1. Unplug power and USB cable. 2. Open door and hold power button. 3. Connect power. 4. Close door, then release power button.
How to Reset waste ink counter using Resetter
1. Download software for Canon iP1200 printer. DOWNLOAD 2. Unzip downloaded file to any location using, 7ZIp, WinRAR, Winzip, etc 3. Run GeneralTool.exe 4. select connected USB port number from USB port 5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION 6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. the selected waste ink counter will be reset.
Thank you for posting. Hope this helps.
Jul 06, 2011 | Canon PIXMA iP1200 Photo Printer
How to download the files from sokkia total station 1030 r
To Down load pls let me know com set up (Sokkia 1030R instrument)
BAud rate ,parity & Bits
May 18, 2010 | GPS
Getting error code 279 on my Disto Classic 5a
can not measure distance.
each time the button is pressed dist, 279 error appears.
Aug 12, 2009 | Leica Disto A6 Laser Distance Meter
hope this helps
Dale
Mar 21, 2009 | Measuring Tools & Sensors
Measuring Tools & Sensors Logo
135 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
