Kenmore 80 series model 23822100 will agitate but won't drain, rinse, or spin. It is as if the timer won't kick in to the next cycle. When I put the timer manually on the next cycle...nothing.
If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
NOTE: There is no need to drain the washer to repair the lid switch. However, if you need to drain the washer to avoid having stagnant water in the tub, you can by-pass the lid switch. Use the steps provided to access the lid swtich. Unplug the switch and remove it from the washer. With the switch in your hand, cut the connector plug off leaving about two inches of wire. Cut the center conductor (green wire) off flush with the plug. Take the two black wires and crimp them together and insulate with some electrical tape, or use a wire lug. You now have made yourself a by-pass plug. Plug this back into the timer plug and you have now by-passed the lid switch.
NOTE: This is to only be used as a TEMPORARY means of operating the washer and not as a permanent fix. The lid switch is installed as a safety feature to stop the washer motion when the lid is opened. Without it, you will not be able to stop the washer unless you push the timer knob in. Make sure you replace the lid switch.
If you have questions, please let me know. I hope this helps you.
