Epson Stylus C66 Inkjet Printer Logo
Posted on Aug 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, epson c66 has 2 red lights on. no paper stuck and cant move the cartridges to change. any idea
yashan.co.in
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 202 Answers
  • Posted on Aug 10, 2009
yashan.co.in
Expert
Level 2:
Mentor:
Answers
202
Questions
0
Helped
79840
Points
602
Hi dude
your printer's ink waste pads are full and the counter needs resetting Try this site and software
It allows resetting of the counters, and gives much more control over cleans etc. (Also will allow cleaning when the red Ink light is flashing)
Epson 1400 cartridge carriage jammed
The cleaning unit may still be engaged with the cartridge carriage. There may be a release mechanism on the side of the cleaning unit. The cover will have to be removed to see if that is the case. Another cause could be that the shaft or rail that the carriage travels on is quite dirty. It can be cleaned with alcohol to remove the dirt. That might be what is loading down the motor. Good Luck.
I have cleaned the print heads, replaced cartridges and still can't get text to print. Any idea?
If you have a a solid red light showing you will not get any printing done. On the epson printer which red light is showing? Is it the one for the black or the color? Was that cartridge replaced by you? I have actually seen one cartridge's red light glowing and so replace the cartridge. Then the printer goes through a charging sequence and to my surprise another red light is showing, but this time it's the other cartridge, because the printer was already low on that color and the charging cycle emptied that cartridge enough to trigger the light to start blinking on and off. Now suppose it's the same light that is still on even after you replaced the cartridge. Do this: hold the paper in feed button for about 3 seconds. The printhead will move to the left. Lift up the clamp of the cartridge that
has the red light glowing and bring it down somewhat definitively again to lock the cartridge down. There is a microswitch that is reset when this is done that tells the printer it has a new cartridge installed. Sometimes when a cartridge is replaced the switch is not reset if the clamping process is not definitive enough, or it simply needs to be done again. When you've done this push the paper infeed button again to move the head back to park postition.
Good luck,
How to change cartridges epson stylus sx 400
From older Epsons: If the ink cartridges are empty (red light on), hold the ink switch 3 seconds to move the print head to the left. If they are not empty, hold paper switch until print head moves left. Once you remove a cartridge you can't reuse it, even if there's ink in it according to Epson.
1helpful
Red warning lights remain on.....
Ink and paper light on : head carriage error/general error. Head can't move extremely to right : head carriage blocked or CR motor error. Turn of printer, unlock head carriage lock. Move head left and back to right (to parking position). Is it move freely?
1helpful
Our printers epson c42ux red light is on stand still
A permanently on red light can mean several things. If the green light is also ON, it means that you heve no paper loaded, an empty or faulty ink cartridge, or a jammed paper feed. I presume you have loaded paper. You say you have changed the ink cartridges. Note that BOTH cartridges must have ink for the printer to work. The simplest way to check this, or to check for a faulty cartridge, is to try another new set of cartridges - compatible cartridges are very cheap on EBay - about £3 a set in the UK.
To check for jammed paper, remove the paper from the sheet feeder and look carefully inside it, and inside the printer (lift the lid) for scraps of jammed paper. Remove any you see. Press the ink/paper feed button and see if it goes through a paper feed cycle. Reinsert the paper and try it again. If it works, turn the printer off and on again, and it should now be OK.
If the green light is OFF, it means you have a Carriage problem, i.e. something is fouling the print head when it tries to go from side to side. Check this with manual movement. Turn the printer off. After a few seconds, turn it back on again. As soon as the print head moves, pull the power cord out of the back of the printer. You should now be able to move the print head across to the left side (gently!) by hand, then move it back to the right and see if it will go fully into its parking bay at the right hand end. You should be able to tell if someting is hindering its movement anywhere.
Please report back with a new comment if none of this solves the problem.
2answers
Epson 1280 Solid red mainteance light
Hi-
Is iot on the position where you can install the ink cartridge? try turning it off and unplug it from power supply then after 10mins replug and turn it back on. keep me posted, but if it will do the same thing chances are there is something wrong with the belts on it, better have it fix or have it check. Thanks for using fixya!!
C43sx both lights on
ok...start by removing the drivers from control panel, go to website and get new drivers, install them, try it again.
http://tinyurl.com/6qcpgy
1helpful
3answers
Epson c43sx does not print
change the cartridge thats simple red light indicating you must change your catridge
2helpful
4answers
If your PC is connecting to it normally (no connection errors), it sounds like you printer is having the service reset hardware problem. Try installing the EPSON reset software and check all counters and error codes.
Try this one which fixed mine:
http://www.ssclg.com/epsone.shtml
Good luck...
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
