Do not know how to connect my new HB954TB LG home theatre system to my LG 42inch plasma TV.
Posted by kimathi on
Anonymous
  • 29 Answers
Connect speakers to amp
connect bluray player etc via HDMI in
Then single HDMI (labelled HDMI out) to the tv. The LG will automatically switch to the correct input
Posted on Aug 12, 2009
Why do USB video's play through LG Plasma but not through Panasonic SC-BTT190 home theatre system?
Its really a software type problem i have a sony hometheatre that wont play certain videos. When tvs/home theatres are made they get whatever software that is put in witch most videos require the basic stuff sometimes its outdated or just not compatable.
Jan 02, 2013 | Panasonic Sc Btt190 3d Blu Ray Home...
How do i connect the tv to a Sony HT-DDW7600 Home theatre system
Use HDMI cable to connect the television and home theater.You can see the HDMI input at the back of your television and the HDMI output of the home theater at back of your player.
Jul 02, 2011 | LG 50PG20 50 in. Plasma HDTV
I have a LG ht502 home theatre , black and white only
Sir avservice, I have also posted a problem about an HT502 DVD receiver + Home Theater. The sound won't come out of the speakers but only of the Plasma tv. But was working before. And the word "PROTECTION" is appearing on the display screen of the dvd receiver. But good quality picture on the plasma tv. Please help
Jul 20, 2009 | Jensen JHT-350 System
How to set up 6.1 divinci home theatre system to 42inch HHD LCD T
davinci DA-6.1 home theatre tokk it out of box their is only speaker wires that connect on to another no power source or wires to tv I need help
Jun 27, 2009 | Audio Players & Recorders
Ghosting of picture from a Panasonic home cinema system
There must be a fault in the screening of the internal wiring to the scart outlet in the home theatre system. I simply changed the way the player was connected to the TV and the interference disappeared:-
1.) I used the RCA video outlet instead of the scart lead. Picture quality was not compromised. FYI the Panasonic Plasma TV I have has only RGB video input sockets at the back, so I used a scart to RCA adaptor to overcome this problem of connecting old technology to new.
2.) The surround sound when playing DVDs is generated directly from the home theatre system so there was no need to connect the audio from the home theatre system to the TV
3.) I used a pair of RCA leads to connect the "audio out" from the TV to the "audio in"on the home theatre system to provide the option of TV sound through the home theatre system.
Mar 18, 2009 | Panasonic Televison & Video
TV Audio won't come through the Home Theatre Speakers
why it doesn't come. just connect the RCA cable to the output pins of TV and connect them to the input female jacks of home theatre receiver. or if the TV has optical out and the home theatre reciever had optical in. thats the best option. just connect one optical cable to enjoy the 5.1 sound. tell me clear problem if u r nt solved.
[email protected]
kanny-sounds.blogspot.com
Jan 26, 2009 | RCA RT2620 Home Theatre System System
Can't wire up to LG plasma HELP
Ah, I assume you have put rca's from the TV audio out to the Audio in of the Theatre System! Then put the Audio System to Aux 1 / 2 and you should have sound through your Theatre System!
Feb 20, 2008 | Sony DAV-S500 System
How to redirect the sound of my new LG 52" HDTV LCD to my LG home theatre?
There sould be audio outputs on the back of it, and the manual should clearly show how to set up a home theatre with an external sound system and all.
I don't know what kind of sound system you have, but I think it might be best to connect your video source (typically DVD player) to your sound system, as it usually can be done better that way. No need to introduce another link in the chain (your TV) that could degrade sound. Also any external tuner could (should) be connected to your sound system directly.
If you use the internal tuner in your TV to watch TV the audio out is your option. Best way to get this right is to consult the manual. They usually have some diagrams that shows a few options of how to do it.
Dec 05, 2007 | LG 42LC2D 42 in. LCD HDTV
Home theater system connections
Hi
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Oct 15, 2007 | LG 42PC5D Television
187 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
