Question about Golf
Have a 2012 HDK 36 volt golf cart. My problem is that none of the other electric items work
My problem is that none of the other electric items work ( horn, lights, turn indicators, reverse beeper I have checked the wiring and fuses can find NO problem with those. Looking for some HELP. Is there some hidden thing that would cause this to happen ?
Posted by Cletus Smith on
5 Related Answers
Robert Debison
  • 412 Answers
SOURCE: lost alot of electrical items.....
sounds like your underhood fuseblock has gone bad..check for corrosion on underside and in connectors..have seen lots of problems with these
Posted on May 21, 2009
Anonymous
SOURCE: 48 VOLT GOLF CART ''BATTERIES'' HELP !!! CURIOUS
Sams club $77 each
Posted on Jul 24, 2009
golfcartman
  • 34 Answers
SOURCE: 1999 ezgo golf cart.need to know the whole wireing
When you removed the batteries, a certain procedure MUST be followed. Key switch off, switch to tow position and shift lever in reverse. You must wait until the beeper unit sound dies out then remove the wire from the most NEGATIVE cable. Place in Neutral before installing new batteries. There is a specific sequence to putting the batteries in an EZ-GO cart. Failure to follow this procedure will kill the controller. The Key switch must be off and the maintenance/tow switch MUST be in the tow position when connecting the batteries. Any of the above will cause the controller to fail, due to improper discharge of the PRE-Charge capacitors.
Posted on Apr 22, 2010
skychief2001
Stephen
  • 21873 Answers
SOURCE: I have an ezgo electric golf cart and I have now replaced the 60 amp link fuse that connects to the battery and black wire. When driving the golf cart just quits and when checking the fuse is blow. Th
This is not a car question, but generally speaking a fuse blows when the current in the circuit exceeds the limit of the fuse.
I would look at the amp draw of the motor if that is what runs on that circuit and also the connections. It could be that the motor brushes are wearing out and the motor is pulling too much current.
I'm somewhat lost on your description - - you say it is a 60amp fuseable link but you bought 20 amp fuses. Are you dealing with two different circuits ?
Posted on Jul 24, 2012
No horn and no right hand turn signal bulb good,icannot find fuse to the horn ifound signal fuse it is good
Horn also uses a relay . What year , make , model vehicle. The odds of the fuse being the falt are high , Fuse's do blow , but not for no reason . Short's to ground cause fuse's to blow . Which means electrical wiring problems or short's in electrical componets . Do you know what a relay is an how it works ?
VEHICLE RELAYS Operation Diagnosis
Do you know what electrical wiring diagrams are ? How to use to pin point areas in a electrical circuit ,to test with a DVOM - digital volt ohmmeter ?
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
Free wiring diagrams here http://www.bbbind.com/free-tsb look under electrical distribution - power distribution . fuse panel . will show fuse layout .
Feb 01, 2018 | Cars & Trucks
What fuse works the back up beeper
It's probably hooked to the reverse light circuit. See if you have reverse lights, if so then go to where the beeper was wired in and see if they did a good job or a tape job. taped stuff will always develop a problem over time. if you got power to it while in reverse but it ain't beepin-you know what to do.
Jan 30, 2015 | Cars & Trucks
Me horn and indicators dont go. checked fuses and they are fine. dont know where to start.
horn check it works as they can go, relay is probably gone for the indicators. its usually a green relay, but if its original it could be any color. they not on the same wiring as each other.
Dec 13, 2017 | Electronics - Others
2000 Honda Odyssey. The passenger side headlamp burned out and I replaced it, no issues two days ago. Battery was cranking slowly and terminals were corroded so I cleaned them. Last night in 15 degree...
The driver's Multiplex Control System is a small computer that controls (among many other things) the dash lights brightness, ignition key interlock, shift interlock, and has a tie in to the brake light system and horn relay. It may be that this small computer malfunctioned and started the whole problem chain.
However, I note from the factory shop manual that if polarity is reversed on the shift interlock--it can be damaged. Reverse polarity will ruin the diode inside the shift interlock. This could have happened when you jumped the battery--a brief period of getting the cables and terminals mixed up could have done it.
Checking the shift lock solenoid can be done by removing the steering column upper cover. Disconnect the shift lock solenoid connector (2 terminals). Using long jumper wires, apply battery voltage to terminal 1 (yellow wire side) of the solenoid and ground terminal 2 (green wire side). Check that the shift lever can now be moved out of Park. NOTE: applying voltage in the opposite direction of that above will damage the diode in the solenoid and will probably ruin it. Remove your jumpers and shift back to park and check that the solenoid locks. If the solenoid does not work properly, it will need to be replaced. This involves removing the end of the transmission shift cable and is a complex job. Remember, no power to the solenoid equals a locked solenoid--it takes power to unlock it.
The Multiplex Control Unit has a self diagnostic feature which checks the computer itself and inputs to the computer. The computer check is called mode 1 and the input test is mode 2. The diagnostic trouble codes are outputted to the ignition key light and beeper.
To test, first confirm that all fuses are good, especially fuse 9 (10A) in the driver's under dash fuse box (left kick panel) and fuse 13 (7.5A) in the passenger's under dash fuse box (right kick panel). Then use a jumper wire (a wire with small alligator clips on each end works best) to jump the two leads of the multiplex test connector. (This is a light green 2 terminal connector dangling from the same wire bundle as the brake pedal switch connector.) Buckle the driver's seat belt (avoids nuisance beeps). Now turn the ignition switch to on. After about 5 seconds, the ignition key light should come on and the beeper should beep for 2 seconds then stop for .2 sec. then beep once for .2 seconds. This indicates that the system is in diagnostic mode 1.
If no diagnostic trouble codes (DTC's) are present, the key light and beeper will not blink/beep again. If there are codes: about one second after entering mode 1, the key light and beeper will indicate the DTC and repeat it every 3 seconds. If there are more than one, the system will indicate them in ascending order. The codes will be a light flash and beep so you will have to count the flashes/beeps to keep track. The codes range from 1 to 6. Code 3 (three flashes/beeps) indicates a problem with the multiplex control unit itself. Write back here for other codes or for questions about mode 2.
Jan 23, 2011 | 2000 Honda Odyssey
Indicator problems, Kawasaki ZXR 750 91'
try a new flasher can, if you remove it and jump the two wires together, the indicators should come on but not flash when you move the lever, check the fuse as well, though youve probably done that
May 02, 2010 | 1991 kawasaki ZXR 750
I have a 2005 toyota tundra with rear parking sensor that stopped working any trouble shooting ideas?
check the fuse for that circuit.there is a beeper under the dash as well.put a test light on it and see if it flashes,that means the beeper is dead.remove the switch if there is one that turns it off and jumper across it,and check the circuit from the shifter wiring to it,and also the reverse lights,they may have it wired to the reverse lights.
Apr 26, 2010 | 2004 Toyota Tundra
Accessory fuse keeps blowing, headlight not working
I know this sounds aomewhat general, however please give the following some thought:
Check your relays, if you have an aftermarket horn you may have a different relay. To troubleshoot unplug your headlight, unplug your horn, etc.. Turn your ignition switch to accessory only. See if the fuse pops. If it does unplug whatever added accessories you may have still have plugged in. Once you can get the fuse to stop popping, turn the ignition switch to on. Then one at a time plug you accessory, headlight, etc. back in. When you find what pops the fuse, unplug that item, start plugging in the other items, if the fuse has not popped you have potentially isolated the circuit causing the issue. Now check the wiring for loose connections, bad ground, and CHECK the relay if that item has one. Hope this helps,
JP
Aug 17, 2009 | 2000 Harley Davidson FLSTC Heritage...
Lost alot of electrical items.....
Apr 14, 2009 | 2005 Dodge Caravan
Tripping fuses
find what fuse is, You have to follow the wires with patience, from the fuse box to the item, you have a short circuit look if the horn + wire is not touching metal outside or inside the steering column, have You replaced the steering wheel? if the same fuse covers the dome light, take it a part and see if the + wire is touching the inside of the roof, plastic melted, or look at the on and off Dome switches at both doors, look for the positive wire on radio, antenna and main light switch, yo can disconnect every item and check any time hot wiring that fuse with copper wire every time, to You are sure
Jan 21, 2009 | 1987 Chevrolet Monte Carlo
Golf Logo
229 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
