Question about Samsung Televison & Video
My Samsung flatscreen tvs red light keeps blinlume goes down to zero on its own and we cant control iy
Posted by barbara on
3 Related Answers
Anonymous
  • 18 Answers
SOURCE: ps2 light gun problem
it'll work just make sure you've got the right one or size or check the wires to find a slit or puncture
Posted on Feb 01, 2008
Anonymous
  • 608 Answers
SOURCE: samsung 62" flatscreen suddenly stopped
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV(warranty was expired ofcourse) and found four bulged capacitors. Many electronic companies were sold capacitors that failed in 2-5 yearsinstead of 10-20. The capacitors failprematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices. Here are some options . 1. 1. Have it fixed by a professional 2. 2.. Dig into your TV, find PSB, Check for faultycaps. If you find some(bulged orleaking) bad caps replace the entire board 3. 3. Remove and then replace individual faultycaps. This takes some solderingskill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds.
Hope this helps
Posted on Dec 10, 2010
SD Tech
SD Tech
  • 14553 Answers
SOURCE: Samsung le46 lcd tv sound goes down to zero when turned back up returns to zero imediatly bar stays on scrreen showing zero
Listen carefully:
The volume down is likely bad on the set, this happens a lot and I will explain why and what needs to be done.
All sets with exterior controls, volume, on/off you name it behind each plastic button is a tiny switch---a push switch that when released stops.
Bad ones develop not from age but poor quality,,,,that is a momentary switch, as long as held it should function and when released stop.
Be thankful it is not the sound UP as I have seen that, Menu, you name it.
Now to the proof and the solution, Someone has to gain access to that switch under that plastic button and remove it from the small circuit board it is soldered into---2 to four solder connections and remove the switch.
A ten year old with a soldering iron can do it.
With it removed power set back and see, if problem gone you have a few choices (really no choice if it was me) order and replace the entire board with all the buttons affected or DO NOT PUT THE BAD SWITCH BACK AND just use the set with the remote.
For the technical minded first the reason a remote will not stop this is buttons on the set have priority over the remote functions and YES you can test the bad switch and find it that way---I have seen ones not being pressed that read as low as 3 thousand ohms or less and that is bad=====there should be no reading across the two pins that are for that switch itself.
Let me know if you have questions, PS none of them sell the individual parts you have to buy the same poor quality board with another set of switches on it.
Posted on Dec 11, 2012
1helpful
I have a 43” flatscreen tv that turns on using volume buttons and turns off same buttons. Volume goes to zero by itself too. Sometimes change channel by itself. I’m sure it’s a control board problem but...
Hi Stephen, yes, it is almost certain that the problem is in the function or control board, usually there is a surface capacitor (SMD) that goes into loss and causes these failures
Another possibility, would be the remote control, which works erratically, remove the remote control or keep it in a closed place and check if the fault continues
Comment the results
Greetings Franco Dosil
Hola Stephen, si, es casi seguro que el problema esta en la placa de funciones o control, por lo general hay un capacitor de superficie (SMD) que entra en perdida y provoca estas fallas
Otra posibilidad, seria el control remoto, que funciona erratico, retira el control remoto o guardalo en un lugar cerrado y verifica si continua la falla
Comenta los resultados
Saludos Franco Dosil
Need code and directions to program a samsung flatscreen
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
On my 2005 F/expdn, if I am on red light stop, when rpm goes under 50 x 1000 my car shutdown. If I keep it above 50 by pressing accelrator is OK, pl suggest
1st your car should not idle below 110 rpm even in gear
idle problems on these are caused by both broken or open vac ports or a dirty throttle body the A/F ratio cant get a correct reading
Samsung PN58c590 plasma tv
Short circuited component/s at its main board. These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating, to many popular brand TVs and other devices.Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
If my akai flatscreen 32in tv is moved or if the power goes out sometimes I plug it back in and the red light doesn't come on. Other times is when I'm watching it and I turn it off it goes from...
bad joint remove back panel with tv off check for any bad joints on power board also caused by thermal fault with tv on use a heat source over boards till tv shuts down then check suspect board
I have 2004 dodge durango the battery light keep blinkin on and off and the speedometer hand go down to zero and the RPM hand goes down to i change the alternator
It may be the alternator, but then it can be the wiring or the powertrain control module as well, it controls the voltage output..
1helpful
2answers
How do i reprgram my 00084J for my new samsung
I found a list of codes in my old Technics Hi-Fi system SADX940 that also work with this remote. So it seems the codes are universal, and even though some people claim that this remote cannot control Philips TVs because it is not a real "Universal Remote", it does. I held down the TV POWER button and entered code "06" and my old Philips TV responded with channel and volume settings - just the job. Hope it helps.
Red light flashing on samsung le40a stuck in standby mode
hi nick think it may be blown capacitors on your power input board?
2answers
Tv help
This is bad. You need to either be under warranty on these big screen TVs or get the service manual. Especially since this is an off brand.
Open Questions:
Televison & Video Logo
Ekse
Demonic-2011
Demonic-2011
