Microwave Ovens Logo
Posted on Aug 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Glass plate does not rotate - Microwave Ovens
advanceda76
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 100 Answers
  • Posted on Aug 10, 2009
advanceda76
Expert
Level 2:
Cheetah:
Answers
100
Questions
0
Helped
25877
Points
241
On the bottom of the micro underneath the shield there is a small moter for turning the plate.. also if the plate and roller are not centerd correctly it will not turn ,.. remove the plate and balence a glass on the triangle in the center of the micro shut door and start micro observe if turning ..also some micros have a button selection on the control to reverse the micro plate rotation and stop it --check these things and get back to me..
3 Related Answers
tiway1
Tim martin
  • 100 Answers
  • Posted on Jun 30, 2008
SOURCE: Maytag Microwave Glass Plate that rotates
check with www.microwaveglasstrays.com
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Oct 06, 2009
SOURCE: One of the legs supporting the glass plate is
You can order parts for this brand from Encompass . Or you can call them toll-free at 866-779-5835.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Aug 23, 2010
SOURCE: Panasonic Microwave Model NN-H765BF will rotate
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can order parts Encompass here or call them toll-free at 866-779-5835.
Here are a couple videos that show you how to replace the turntable motor and diagnose
Where can I get a glass turntable
Are you talking about just a new glass plate for your specific oven or a generic turntable mechanism? If just a glass plate, you have provided no brand or model info. Just examine how your old plate engaged - they aren't all the same but some will interchange. There are also inexpensive turntable devices that can be used to retrofit ovens without a rotating mechanism.
9helpful
Glass turntable in tricity tmc209 says "microwave only" What do I use for convection or combi cooking? Does turntable still need to rotate for convection cooking?
definately dont use the standard glass plate for convectional 'oven' cooking, as it will shatter. i have had TWO plates shatter so far before realising they should only be used for microwave cooking.
The revolving glass plate on Panasonic NN-GD546 no longer revolve
the plate is controlled by a rotating motor.the motor is probably stuck or bad.
Microwave lights up and glass plate rotates but no heat. Also, unsure how to remove microwave from its surround within kitchen unit.
to almost all of the no heat microwave issues suggest calling company about warranty because the warranty may cover problems like these up to five years and taking them apart will almost certainly void it. Magnatron is likely cause for problem.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
