Question about Westinghouse Televison & Video
Westinghouse tv. I can't get my remote to work and My TV is in Spanish. How do I get it in english
Posted by Jeri Ford on
David Spradling
    Top Expert:
  • Westinghouse Master
  • 11,347 Answers
Go into audio settings and put in english or factory reset
Posted on Apr 18, 2020
5 Related Answers
lukster
Luther Stephens
  • 217 Answers
SOURCE: HELP PLEASE
you should be able to use the control panel on the set, sometimes it's a little tricky, but if you keep trying you will get the right settings
Posted on Feb 17, 2007
Anonymous
SOURCE: Direct TV remote, need code for Westinghouse Flat Screen 32" [email protected]
11100 worked for me!
Posted on Apr 07, 2009
Anonymous
SOURCE: can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
Posted on May 08, 2009
Anonymous
SOURCE: Why did the TV remote input stop working?
It worked for me too. Thanks
Posted on Mar 31, 2010
Anonymous
  • 117 Answers
SOURCE: Westinghouse Flat Screen TV will not power on
caps in power supply
Posted on Jun 23, 2010
Stuck in "Spanish mode screen will not come up to put back in English.
It really depends on the television in question, but generally you just hit Menu on your remote, scroll down to language, and select English. Every TV is different though, so if this does not work for you, I will need the make and model of the TV to be more accurate.
Feb 23, 2017 | Televison & Video
My tv model no PDP42G20024 is stuck in spanish and the only button on remote that working is the power button therefor the 4 button reset is unable to be performed
U WILL HAVE GET A DICTIONARY ON SPANISH TO ENGLISH THEN ACCESS THE MENU IN SPANISH LOOKING FIR THE SPANISH WORD MEANING LANGUAGE HIGHLIGHT IT A LIST OF LANGUAGE WILL APPEAR SCROLL TO THE ONE MEANING ENGLISH...OR ANGLEE ENTER AND SAVE U R BACK TO YA KIND
Oct 08, 2015 | LG Televison & Video
Can I default my 32in vizio tv. I am stuck in spanish and want to go back to english?
select MENU on your tv remote.
choose settings
select language
Choose English
Apr 25, 2014 | Vizio M320NV 32in 1080p LED HDTV and Mount
Change language from Spanish to English Vizio 323SV
You may have to go back to the setup procedure and search for a language option to select English.
Dec 19, 2013 | Vizio VO320E LCD TV
Remote is set on spanish I need English
Language selection is made during initial setup of the TV. The remote has nothing to do with language selection.
Nov 20, 2013 | Coby TV Remote Control
How do i reset audio language on tv?
Go to setup menu on the TV using the remote and select English from the language option and press OK. You may need to browse through the setup menu to locate the language option.
Jun 26, 2013 | Westinghouse Televison & Video
I have a rca colortrak plus and lost the remote. How can i set it up to work with a converter box? It is displaying in spanish and I can't change back to english
You may be able if can enter the menu to change from Spanish back to English--(very old set) by using vol or channel buttons to navigate--this is not certain but possible--idioma is word to look for--language.
Apr 25, 2012 | Televison & Video
My tv is in spanish
The only remote I was able to find that work all Ilo features is the GE universal remote #24914 works to change your Ilo tv from analog to digital and switch to vid1 or vid2 ect.... The code is in the book that comes with the remote. I use this remote myself. This remote can be bought at Target for under $10. This remote will let you get it back to english. You should also be able to do it from the menu button on your tv.
Mar 11, 2009 | iLO IWT3206 TV
Wrong language
In the menu one of the first options is language. If it is in spanish you may have to get someone that reads spanish to tell where this option in the menu is. Most new remote hand units have up and down and side to side arrows. Clicking the right side arrow usually will make selections, When you get to english if there is a select button or enter in the middle of the arrows, push that button if english is high-lighted or underlined or different color. Paul
Sep 23, 2007 | RCA E13319 13" TV
Televison & Video Logo
54 people viewed this question
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
