I have a ethernet going from my comcast modem straight to my ps2 and when i try to set up a account it lets me and when i do a connection test its successful but when i try to play madden nfl and play online it says something like no ea account found and its also says it timed out how can i fix this promblem
Electronic Arts closed the servers to all games older than 3 years to make room for the new onesElectronic Arts closed the servers to all games older than 3 years to make room for the new ones
You can't post conmments that contain an email address.
Do you have it hooked up to the computer or the modem.The ethernet from the console connects into the modem so firewall should not be an issue.Also,most games only support the 2 latest versions of the game for online play.If you are getting a could not find server message or something similar,your game is no longer online playable.Like now would be Madden 2009 and 10 only.If you have it hooked up like I said,just post a comment to this and I will get an auto email with your comment.
Good luck! Greg
Ok first off create a psn account online via computer, this is free of charge. Then after that connect your ps3 via cable to your modem. turn it on and access network settings. Then select internet connection settings, select easy. After it is finished select test connection. Should this time out it means you have a faulty connector somewhere, try checking your cables and the ports on the ps3 and modem. But if it states connected, back out and go to network via your ps3 dashboard then select sign in and enter your account info from your psn account.
So long as the modem uses an ethernet connection, it should work. The ethernet cable that you normally route into your computer, simply plug it in the ethernet plug on the back of the ps2. When you use an online multiplayer enabled game, you'll simply have to go through the setup of it registering your information.
Turns out you can absolutely use the PS2 to play online games!
You need to buy a NETWORK ADAPTER for it, which is in itself a 56K
modem that includes a ETHERNET plug, so you can connect with just a
regular phone line (slow), or connect your broadband modem/router by
way of the ETHERNET cable (fast!)
You may need to buy a MEMORY CARD, and even a HARD DRIVE for some games, so its not free there.....
The information is a bit extensive for all the questions you may have,
so I have included the following great links for you to peruse.
The Ethernet port works with PS2 Games that are setup for Online play. This Port allows for Online plays with the PS2. If should not be that complicated when you have a online game loaded.
To connect to the internetfor online gaming(you cannot surf the web with a PS2) you simply needto buy a "PS2 Network Adapter". It hooks to the back of your PS2 systembehind the removable plate, and you connect either a standard phoneline, or an Ethernet cable into it. A bonus is that there are nomonthly payments like the XBOX system, so all you have to do is buy theadapter and you are set.
Justbuy that adapter and follow the instructions that come with it. I willhave to warn you though, the PS2 online community is not linked to thePS3 online community, so there may not be many players to play againstsince most of them do not use the PS2 online anymore.
There should be a setup disk that came with the network adapter.
Put that in, and it's a simple walk-through.
If you don't have it, then Madden 08 has an automatic connection sequence, just go online with it, and it should do it all for you.
If you have a cable connection (Cable Broadband), then its going to DHCP connection (or automatic) If it's DSL, then you may have a static IP address, and you may want to contact your ISP for further help. You would need to manually assign an IP address to your PS2.
If you have it set up correctly, and its a cable modem you've got, then you may want to reboot everything.
Unplug power to the modem and router and also make sure the PS2 is off.
Plug modem back in, then router, and turn PS2 and try connecting agian.
I experienced the same problem. I have the ps2 slim. The problem was so bad that i had the slim for about 3 years and still could not play any ea games online. About 2 months ago i finally got it to work though, allowing me to play madden ncaa and many other sports games from ea. I also have dsl broadband just like you. I do not have a router though. I just hooked my ethernet cord straight into the back on the ps2, my computer is really close by. I would reccomend a router though.
Enough of this bs though. Now solving the problem. There was actually a firewall keeping me from connecting to ea servers. Which in turn meant no ea account and no ea play online. Go onto your computer and turn your FIREWALLS OFF. This still may not work though. I done this and an unknown firewall was still blocking it. THERE WAS A FIREWALL IN MY MODEM.
CALL UP YOUR INTERNET SERVICE PEOPLE AND TELL THEM TO TAKE THE ******* THING OFF SO U CAN ******* PLAY. I ALSO FOUND THAT LIMEWIRE WOULD NOW WORK ON MY COMPUTER AS WELL.
By doing this you will open peer to peer connections with other programs and players online.
On some models, the Ethernet comes from a PC board searate from the Motherboard. Now you can get a motherboard replaced for under $60. Check out the playstationclinic. Nothing you can really do if the Ethernet Chip is blasted.
Your PS2 should get these settings automatically. It's very rare to have to manually configure those settings, but it would be done in the control panel that comes up if you turn it on without a game disc in the drive.
But I don't think that's your problem.
Many cable modems "lock on" to the first network device that is plugged into them when they are first turned on.
Try unplugging your cable modem for about 10 seconds, and then try it again.
