Question about Pioneer Elite PRO-1140HD 50 in. Plasma HDTV
My remote will not perform any functions with the Plasma TV. No Volume, Channel, Input, TV (off/on) etc.
Posted by dallasrsmith on
andrew
    New Friend:
This is an old post but I have similar problem now. My remote is working. I ththink it's the IR sensor. Where can I buy the component? Where can I cget the part number? My TV is Pioneer PDP-4214HD
Posted on Mar 20, 2013
Ben Wabnick
  • 2,404 Answers
If you have fresh batteries in your remote and its still not working, then try another remote and if you can't get another remote to work with the TV then you know its not a remote problem and its more then likely a problem with the IR sensor in the Plasma TV.
If thats your case after doing your troubleshooting then see if your Pioneer Plasma tv is under warranty, if it is contact Pioneer to get the TV covered under warranty. If its not then you would need to contact Pioneer to get the part # for the IR sensor on the plasma tv.
Then depending on price you can buy it from them or do a search on google to find the best price for the IR Sensor.
Posted on Aug 10, 2009
What code do I need for GE universal remote for Ario tv model 3269?
Universal remotes only cover the most basic functions (on/off, volume, channel) - they do not allow for menus , input selection, etc.
And code data, if available, is gotten on the web site for the universal remote. U can try attached site for remotes that might work for you. MCM Electronics Home and Pro Audio Video Security and Test Equipment
Nov 21, 2015 | Ario HC3269 32" LCD TV
Need code for sky remote control for samsung model ps51d450 51inch plasma tv
Hello
Sky remote codes for Samsung TV are:
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 30, 2011 | Samsung Televison & Video
I have a Samsung remote and a vizio tv. I need the code to enter for the remote to work the tv.
I have the 32" Vizio VP322 plasma HDTV and code 19 and 78 both work but only for power, volume and channel, doesn't work for input selection
Nov 20, 2010 | Zenith ZEN700 Remote Control
We have a 42' plasma flat screen model PD46C10. All of a sudden it went to a white screen with daewoo in blue. No remote function, no controls function on TV base. Won't shut off unless unpluged. Any...
is it perhaps a built in screen saver? try changing channel on remote. or check to see if input is on aux / or component/ dvd etc.. or possibly there is an access code (parental setting) try that first. hope it helps.
Oct 17, 2010 | Daewoo Televison & Video
Insignia NS-PDP50 Plasma TV - Remote Sensor failure
Change batteries.Reboot everythings.Tv unplug,replug couple mins later.Ur Directv box,push off/on for new update software.After that sould work.Rate me after u done this.
Jan 02, 2010 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
TV gettin power...but no pic and no sound
I am Having the same problem as PScott. I will open my TV this weekend wil a friend who is a electrical technitian. We hope that ther is any schematics inside the TV though..
Apr 12, 2007 | Maxent MX-42V1 42 in. Plasma Television
Pioneer Elite PRO-1140HD 50 in. Plasma HDTV Logo
443 people viewed this question
Top Pioneer Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
