You should ask the others what channals they are on if you cant for whatever reason then scan for a frequincy that has others on it by hitting the scan butten and hitting the channal up or channal down butten, if you can tthen talk on each channal in order and wait 10 seconds for a reply then go to another channal and try agean, im not sure if you can hear others unless they have the same brand radio's but i could be wrong, i am also not sure if the scan butten will work so after it goes through all of the channals 2 times then try the other suggestion. you also want to make sure you have good batteries in when you try.
okay this is what you do hit the code search botton hit the tv botton the hit channal up untell you find that your tv is changing channals then hit tv again and that should work just do it slow becouse if you pass the channal it changes then you will have to use the channal back button tell it pops up again it will work.
That's because this is a quad. It compresses all 4 video feeds into 1 file. When you play it back, it decompresses the video and shows you each camera. Playback through this unit is the only way to see 1 camera at a time.
To be able to copy 1 camera shot to a DVD, this is what you need to do:
You need to have a TV with Video in and Video out jacks.
Connect the Quad to the TV Video in jack and connect the TV Video out jack to your DVD Video in jack. Playback a single camera shot on the quad to the TV and hit record on your DVD. - The DVD will record whatever is shown on the TV.
Go back in the menu, find (input source)
or (tuner) then click the cursor right
side of the menu button or the left to
move the (TV) to (CATV), after you bring it
up then move cursor arrow up or down to
page (AUTOPROGRAM) then tap the cursor
arrow right of the menu button to start
the CATV channels to be found , be sure
you have the cable connected to the TV.
Once the channels have been found, tap
(EXIT) or (STATUS) button on remote to get
out of the menu and close the page,
or just turn set off and back on again.
Im sorry but you can't without the original remote. If you want to consider getting the remote go to http://www.remote.com or maybe you can borrow one from a freind or a local store that sells Emerson will let you borrow one. Good Luck
