Question about Optics
Parts For a Discovery Kids Telescope
I was given a telescope [ used ] there is no book of instructions or book to order parts.
Posted by Anthony Del Grosso on
5 Related Answers
Anonymous
  • 944 Answers
SOURCE: My goto telescope will not slew upwards.
I'm assuming the motor works fine. First check this link for the instructional video and check you are doing everything right. (you need quicktime to view these - you can download it from the link if you need it ; http://www.meade.com/educational/ds%20videos/qt_chap1.html Here is the link to the Meade warranty page; http://www.meade.com/support/warranties.html If your scope is no longer under warranty, you can get spares here; http://www.meade4m.com/4mshop/parts/ They have fabulous pictures of all the available parts - Check in the "mount parts" section; They show a DS worm gear assembly, and a DS gear and washer set. You can probably see better than me, but it looks as if the worm gear traverses the scope, and the gear and washers in their housing elevate the scope. There may be more than they show parts for. The real trick will be to make sure you know how to reassemble the gears you dismantle - take a photo every time you remove something so you have a record when the replacement parts arrive. It is not the most complicated gear mechanism, but it is reasonably high precision, and relatively cheap materials, so be very careful or get someone fairly gentle and mechanically minded. If you need help, post me some photos back of what you need help with, happy to oblige. Hope this helps:)
Posted on Jul 19, 2007
Anonymous
  • 44 Answers
SOURCE: Sear's Refractoring telescope Parts
Most of the refractors sold by Sears were made by Towa of Japan. These used the Japanese standard .965" barrel diameter eyepieces. These are hardo come by today and usually not worth the hunt. Get an 1.25" to .965" "hybird" star diagonal that will permit the use of 1.25" accessories. Orion sells this item. HTH, Geo.
Posted on Mar 02, 2008
Anonymous
  • 21 Answers
SOURCE: galileo cc-2 parts
Call Galileo at 1.800.548.3537.
I've ordered parts from them before.
And they speak English.
Posted on Aug 11, 2008
SOURCE: instruction manual for Astro Nova 100 telescope
Get a free star chart at:
www.starmaps.com
and go to the Cloudy Nights forum and read the telescope articles.
http://www.cloudynights.com/
Posted on Dec 27, 2008
SOURCE: Just bought a Telescience 3088 telescope used.
You will not find a manual for many of the smaller telescope brands-- however Meade maintains a web site for all of their manuals. Go there and find one that is similar to your style of telescope and down load it for free. Then read it and compare with your telescope.
http://www.meade.com/manuals/index.html
Posted on May 15, 2009
I was just given a bushnell 675x5 from a friend, but he had never used it and didnt have instructions. where could i get a users manual? also it has a couple damaged parts i will order if you could tell...
All of Bushnell's manuals are on this web site-- find your telescope and download a free copy-
http://www.opticsplanet.net/bushnell-warranty.html
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Jul 31, 2011 | Bushnell 675x5 EQ Reflector Telescope
I have a swift astronomical telescope model no. 859 (no D). I need an owners manual and information on how to order parts. Mark J. Lanza
This is a 6 inch Dobsonian mounted reflector. They are VERY simple to assemble-- only two parts-- the base and the tube. The small finder scope goes on top. The eyepiece goes into the focuser. That's it.
No manuals exist for that brand but all of them assemble and are used in the same fashion. Here is a manual for an Orion brand Dobsonian just like your scope.
http://content.telescope.com/rsc/img/catalog/product/instructions/IN_165D_web_XT6-8-10.pdf
Dec 21, 2010 | Swift 859D (300 x 152mm) Telescope
I was given this telescope without an instruction manual and I really have no clue how to use it. I've palyed around a little but not really sure how to get the full benefit of the telscope. Is there any...
This is a small 60mm refractor a very simple telescope. Not much bigger than a pair of 10x50mm binoculars.
Objects in the night sky are very tiny and many are very dim. You must learn the night sky. Buy several good books like "turn Left at Orion", or "Nightwatch".
Sep 20, 2010 | Galileo GM-EQSC 900mm x 60mm astronomical...
Assembly & operating instructions for a Sear's Refactor Telescope Model 24191.
Sorry the only thing available from Sears is this parts list-- not a manual.
http://www.searspartsdirect.com/partsdirect/brands-products/Sears-Parts/Toy-Parts?Type=Telescope
I suspect this is a small REFRACTOR style telescope. You may want to download a Meade telescope manual which is similar to your telescope. They all assemble in a similar fashion.
Look under the REFRACTOR header for one that is similar to your telescope:
Sep 15, 2010 | Sears 127474 Telescope
I was given a Tasco 675 power reflector telescope model #40-114675, but didn't get an instruction book or dvd. I was able to find a star in the finder scope but couldn't see it through the eyepiece. it...
You must first ALIGN the finderscope with the main tube. Locate a bright object with the main telescope. Get it in the eyepiece- then without moving the telescope, align the finder scope on the same object.
Now you can use the finder like a gun site to center targets on the crosshairs. By the way the Fixya picture in your question always makes me laugh- the telescope in the picture is mounted BACKWARDS and pointed toward the ground!
Jun 01, 2010 | Tasco Luminova 40114675 (675 x 114mm)...
I am looking for a manual on how to use it . i was given the telescope from a neighbor for my kids but have no directions for it
Meade maintains a web site for their telescopes. Look under refractor or reflector and download one that is similar to your telescope.
Sep 29, 2009 | Tasco Luminova 40114675 (675 x 114mm)...
I need to find a manual to assemble this telescope.
Meade has a web site with all of the manuals for their telescopes --- look around and find one that is similar in style to your telescope and use it to assemble your scope and learn about the different parts.
Apr 17, 2009 | Optics
Require operating manuel for baytronix 6" reflector
Even if you cannot find a manual-- these web site will help you learn about your reflecting (newtonian) style telescope.
http://www.astro-tom.com/telescopes/telescopes.htm
http://books.google.com/books?hl=en&id=_FPrke6p19AC&dq=reflecting+telescope&printsec=frontcover&source=web&ots=AYjWIOQmwI&sig=zoqu_7z2zGvk0kW6r1WJgZnYNUU&sa=X&oi=book_result&resnum=14&ct=result#PPP1,M1
http://visual.merriam-webster.com/astronomy/astronomical-observation/reflecting-telescope/reflecting-telescope.php explains the different parts of the telescope
Dec 27, 2008 | Meade TeleStar DS-2114ATSA Telescope
Optics Logo
118 people viewed this question
Top Optics Experts
Marvin
Marvin
ray gallant
Are you an Optic Expert? Answer questions, earn points and help others
