When I finish a wash and open the detergent drawer the bleach dispenser is still filled with water.
The bleach dispenser is a syphon system. When you put in the bleach , it fills the reservoir to a point just below the syphon point. Your bleach tray has a tube attached to it, with a loose cap around the tube that causes the bleach to be delivered to the washload when the water is added. Remove the cap over the tube in your bleach tray. You'll also note a similar arrangement for your softener dispenser. Clean both caps and tubes. Make sure that the caps fit properly back down over the tubes. The syphoning effect will work only up to the point that the circuit is broken by air. If your cap sits up too high, the syphon effect is broken early, leaving residue (water) in the dispenser.
Best regards, --W/D--
