Question about Sony PlayStation 2 (PS2) Console
No disc works for PS2
Upon inserting a disc in my PS2 it will go to the PS2 menu that would normally appear when there is no game inside the console.I than go to browser to correct the problem but it will say error (something like that).I have attempted this with numerous fine working games but the outcome remains the same.I'm no good at this kind of problem so any ideas?
Posted by ashouinard4g on
Anonymous
  • 149 Answers
Hi, it sounds like your laser is either dirty or dead. first try to clean your laser with a Q-tip and some glass cleaner (no streaks that way). This will require you opening up your PS2. Take all the screws out of the bottom os it and pull the top off, be careful there is a ribbon cable that is attached to your power and eject buttons. You will be able to see your DVD drive. take all 4 screws out and take the top off. The laser will be right there. Swab the laser with the Q-tip and use the dry end to dry it off. Put the top back on and plug it in to the wall and your t.v. See if it will read the discs before you put it back together. If it won't then your laser is shot and needs replaced. But while you have it apart you can order a new laser for about $29.00 and install it while its apart. If it does read the discs then its fixed and you can put it back together.
Posted on Aug 10, 2009
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
Tip
Try this to play DVD movies on your PS2 if it wont play DVD movies.
If your PS2 works fine with Games and just wont play any DVD movies at all.Then you should try this trick to play movies on your PS2:
  2. Menu screen will appear like:894e4e5.jpg
  3. Press the ps_b_triangle.gif (triangle) Button to enter Version Information Menu that looks like3aef030.jpg
  4. Highlight the Play Station Driver as above and again press ps_b_triangle.gif (triangle).
  6. Highlight the Disc Speed as above and press ps_b_x.gif button,to enter Disc Speed Menu
Be patient and wait till the movie plays itself.If your lens is good then it will play DVD in first go else try again till it PLAY your DVD movie.
Thank you!
on Nov 29, 2009 | Sony PlayStation 2 (PS2) Console
How to fix my playstation 2 that won t read grand theft auto san adreas
Your console is an old one,and your lens too is probably weak.Try cleaning your PS2 lens Watch Video at end of solution to clean your PS2 at home....
You can also follow these steps to make your PS2 to play GTA San Andreas:
  2. On menu screen go to [options] by pressing 'triangle' button.
  3. A new screen will appear select by pressing 'X' [DISC SPEED]and set it to [FAST]
  4. Then insert the game disc.
  5. Turn off your PS2.
  6. Press and Hold the [Reset Button] till the blue light turns on.Release the Reset button and press it again.
It will take a bit more time to play game,but first i recommend you to clean your PS2 lens,watch this video.
I've got something else to add.......you can follow above steps to play DVD movies if your PS2 dont play any.....!!!
Nov 19, 2009 | Sony PlayStation 2 (PS2) Console
Wont load
Disc read errors are mainly due to worn out lens or dirty PS2 lens.Clean your PS2 lens to get rid of this problem if your lens is dirty.Watch this video it will help you to know how to clean your PS2 lens.Watch it carefully.
Remember to keep your PS2 in Dust free environment if you don't want your PS2 lens to get dirty.
If your PS2 can not play certain games like Rock band try this tip:
  5. New screen will appear like
And after that wait till your game is loaded.
Click here to view full tip.
Nov 16, 2009 | Sony PlayStation 2 (PS2) Console
PS2 does not read the disc.
Have you cleaned the laser? Try that first and if that dosen't help then your laser might be dead.
Aug 06, 2009 | Sony PlayStation 2 (PS2) Console
PS2 will not read any disks
you probably will have to take it to get it repaired because its not the disks it your console for sure so try getting it repaired or getting a new one
Aug 04, 2009 | Sony PlayStation 2 (PS2) Console
PS2 wont read discs
This is optical lens assembly failure. you will need to replace this failed assembly in order to restore the normal functions.
Contact Sony for this repair.
Jun 21, 2009 | Sony PlayStation 2 (PS2) Console
Guitar hereo wont work on slimline ps2
I had the same issue (since Christmas).  Today it was rainy, so I spent some time with kids and here is what worked for me
Here's what I did to fix the same problem on my PS2 (Slim model # SCPH-70012). This should work for all models of PS2's. (Slim or Fat). Sony says all models can read a dual layer disc.
1) Start up the PS2 with no disc in it.
2) Highlight the 'Browser' menu and press the 'green triangle' button.
3) Highlight the 'Console' menu and press the 'green triangle' button.
4) Highlight the 'Diagnostics' menu and press the 'blue X' button and select 'ON'.
5) Press the 'red O' button to back out of this menu.
6) Highlight the 'PlaystationDrive' menu and press the 'green triangle' button.
7) Highlight the 'Disc Speed' menu and press the 'blue X' button and select 'FAST'.
8) Press the 'red O' button to back out of this menu.
9) Turn off your PS2.
10) Insert the disc and turn the PS2 back on. The diagnostics should run and automatically adjust your PS2 to play the game. I was amazed! Mine loaded right up after several previous days of nothing.
11) I checked the settings after the initial load and the Diagnostics and Drive speed reset to normal so it must be a one time run thing. My game has loaded everytime since and I haven't had to re-do the settings at all.
I hope this works for you too!!
Mar 16, 2009 | Sony PlayStation 2 (PS2) Console
Disc read error
Disc Read Error generally means that the game disk cannot be read by your console.
Reasons for Disc Read Error
1. Disk surface scratched or smudged.
2. Disk surface dirty.
3. Lens surface dirty.
Here is what you can try doing.
1. Check the game disc for any scratches or smudges on the surface of the game disc, try to clean them off by using a non-abrasive cotton cloth.
2. If the PS2 console is lying down, please set the console to on its side or if it's on its side set it to flat position, restart the console and then try game again. Always ensure the PlayStation 2 is in a cool, well ventilated place.
3. Remove and reinsert the Memory card of your PS2, restart the console then try running the game again.
Other troubleshooting that you can try.
Change the Disc speed of the PS2 DVD and then try again.
Start the PS2 with no disc in a drive. Press the "triangle" button on the controller.
Use the up and down buttons on the controller to select "Playstation Driver” and press the "triangle" button on the controller.
Select Disc speed. If it is set to "Fast," select "Standard"; if it is set to "Standard", select "Fast" and press the "X" button on the controller. Press the "O" button on the controller. Insert the game disc and restart the PS2. Try running the game again.
Turn the Diagnosis On for PlayStation2 to auto detect the best settings.
From the Browser and System Configuration menu. Press the triangle button to select Version. Highlight the Console from the list and press the triangle button - this accesses the next menu option. The Diagnosis will be highlighted. Press the X button to access the options available. Highlight "ON" and press the X button to affect the change. Restart the console and try the game again.
If the above steps does do not solve the error then you would probably have to replace the disc.
Note: If you are using the Slim version of PS2 make sure that the console is properly ventilated and that it should always be in the standing position, as the slim version of PS2 no fan or any other cooling unit unlike the normal PS2.
Oct 13, 2008 | Video Game Consoles & Games
Playstation 2
IF THE DISC IS NOT BEING READ THEN THERE IS SOMETHING WRONG WITH THE LENS INSIDE THE PS2. IF IT IS BEING REA THEN TRY OPENING THE PS2 TAKE OF THE TOP. LOCATE THE TRAY COVER AND THERE IS A WHITE OBJECT IN THE MIDDLE, TRY SPINING IT. IF IT DOSEN'T MOVE THEN PLAY WITH IT UNTIL ITS LOOSE. ThEN TRY PLUGIN BACK THE PS2 AND INSERTING A GAME (DO NOT PUT THE TOP BACK ON) INSERT THE GAME AND SEE IF THE WHITE OBJECT IS TURNING WHEN THE DISC IS READING..
IF IT IS THEN THE DISC IS SPIINNING,
HOPE IT WORKS FOR U.
Dec 27, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
129 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
