Question about Toys
ION idm02 electric drum set, when I edit Drum Set, and I save it, then when I turn it off and turn it on again, it goes back to MEMORY FAIL and the edited thing goes back to its original stan.
Posted by Alfonso Tapia on
5 Related Answers
Anonymous
  • 2985 Answers
SOURCE: how to unprotect the memory card
Check the manual - there is a comprehensive manual in PDF format of the CD
Posted on Aug 01, 2007
leethedeuce
Lee A.
  • 4472 Answers
If I understand correctly what your asking what is the brand and size of the memory card. If I were to take a stab at it right now I would assume there is a lock/unlock switch on the card. Have you had this problem with the card before?
Good luck,
Lee
Posted on Jun 13, 2008
Anonymous
  • 5 Answers
SOURCE: failed creating file
I had to re-do the project, this time using Standard Quality rather than High Quality, and it completed creating the file(s) and writing the DVD.
Bernie
Posted on Jun 30, 2008
Anonymous
SOURCE: Cect p168 problem internet & MMS settings with Rogers Canada
I Have a question ... How can I change the theme on the Cect p168 ??
Posted on Aug 14, 2008
Randy Morton
  • 479 Answers
SOURCE: olympus master 2 won't let me save edited images!! help?
click save as and change location and name
Posted on Apr 07, 2009
I have just purchased a second hand iDM02 drum set (no instructions) but can't get any sound from it. Tried playing the demo but still no sound. I'm not a techy, any ideas please?
Ensure headphones are connected to the correct socket and adjust volume accordingly. If this still doesn't work, you have a faulty item
Dec 21, 2015 | Music
My ion idm02 doesn't make any noise
Is this a car or truck. If so what year?
Sep 10, 2013 | Cars & Trucks
I have an iED01 electronic drum set with and iDM02 module. I have problems with the pads staying in place and the module sliding around the rack bar. Any suggestions?
These can't take the beating that regular acoustic drums can. Don't hit thm as hard as real drums. Also you can wrap PVC tape around the rack bar eithr on both sides of each clamp or, better, right where you want the clamp to thicken the bar which allows the clamp to grip better.
Dec 03, 2010 | ION Audio iED01 Electronic Drum Set
Xerox WorkCentre 4150 Error code: 20-800/The machine cannot save the fax settings to memory. Xerox service is required to inspect the backup battery. Faxing is disabled, printing and all other machines...
One of 2 things.
EIther you have to enter the Fax User memory, Or the memory battery has failed and needs replaced.
Here is what the service documentation says.
(4150) During a power-off period, the machine has lost its user memory. Check that the backup battery, PL 1.10 Item 5 is holding its charge of about +3V. If necessary, install a new battery, PL 1.10 Item 5.
Dec 17, 2009 | Xerox WorkCentre 4150 Black and White...
THE COMPUTER IS IN A POWER SAVING MODE
I think you mean, your display is in power saving mode, this happens when there is no signal from the computer - the display then goes to powersaving mode, try restarting your computer, if it doesn't turn on the display. try the display on another computer to see if your display works.
if your display works with anohter computer, try it again on the problem machine, if its still in the power saving mode, then its not turning on, the computer is not turning on-
I would suggest to get a local friend or a tech to look into your computer and find the issue, if your handy with screwdrivers and know your way inside the computer, then you could take the case open and reseat the memory. try without any memory, then try with just one memory module. Then put them all back in, if this doesn't help, its not a memory related problem.
to save time i recommend you take the computer to a local professional.
Jul 15, 2009 | LG L1915S 19" LCD Monitor
I have the ion idmo2 and I can't get the drum set part to work.I don't have instructions I lost in a move, All the rest is working. My e-mail [email protected] Thanks Joseph
Why not download the .pdf's for it from the manufacturer's page? It's easy!
just go to: http://www.ionaudio.com/contentmgr/showdetails.php/id/1137/tt/4
Then you can save them to your computer and/or print them out.
E N J O Y!
May 18, 2009 | ION Audio iED01 Electronic Drum Set
Goes back to save
delete the save from your hard drive or memory unit. I know it doesnt sound like it would work, but trust me, it does.
Jan 23, 2009 | Microsoft Halo 3 Legendary Edition for...
Ion ied05 Electric drum
I hear it is only on a cd that comes with the set. I am expecting in a few days. Check to see that it is not included with the software you received. Let me know as I will be installing in a few short days.
Dec 25, 2008 | Music
Toys Logo
139 people viewed this question
Top Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
