Question about Lexmark X7170 All-In-One InkJet Printer
Scaner problem, scan whith a lot of lines so colored .What can i do to fix it?
Posted by medeirosjpm on
  • Antony May 11, 2010
    Hi, To see if I got this right, when you scan you get a lines on the pages? Does this happen when you just print?
Scan color pictures
Does this problem happen when scanning either from the scanner glass or the automatic document feeder? Does this problem happen when scanning either from the computer using the Lexmark software or scanning using the Scan button on the printer operator panel? This will help me understand what might be causing this problem.
Feb 12, 2012 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lines on printout of scanned image
The problem is with Scaner.
There will be any dust particle is on the purticular sport of scaner, try to clean the scaner.
If any one or more Photo Diode damage (Used in Scaner which glow) then also the problem will be
there.
Change the scanner if damege (Open the top lead and press copy butten then see any LED is off / not glow)
Jun 02, 2011 | HP Photosmart C5180 All-In-One InkJet...
Light horizontal lines on printout of scan
The Scaner will be faulty.
You try to clean the scaner(The glowing part)
Find out any one or more LED / Light is fault or not glow.
Change the scanner if faulty
When making copies or scaning there is a line that apears on the top, that goes all across the page. how can i fix this? when printing from the computer i.e. microsoft word or printing anything from the...
please your have a scaner use. then open the top pad and put the object in scaner and take atake object the job. you start a scaner then
select to general mode and coloue and dpi select and start a scan and put the object in your word page . and scan object is page in please and give a print and pgae celect to us. and is ok
Sep 24, 2009 | Epson Stylus CX7800 All-In-One InkJet...
Problems whith my hp deskjet f4180
Ok go to all programs -> HP -> HP Solution Centre
Then click Scan.
IT should work now!
Oct 08, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Colorful lines down the scanned pages...
This could be due to excessive usage which the scanner can not tolerate and as a result the movement of the scanning mechanism losses precision. So avoid continous scanning.
Feb 08, 2008 | Microtek ScanMaker 5950 Flatbed Scanner
Scaner does not scan
Printer works well, but the scanner will not scan only leaves a black page
Dec 28, 2007 | HP PSC 2355 All-In-One InkJet Printer
Lexmark X7170 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
