Question about Alphasonik Mayhem PSW912 Car Subwoofer
Which is the size of the box just for one PSW912 to mount
Posted by cyberartu on
Anonymous
    Scholar:
  • 129 Answers
I used to compete with these subs, and found that for street beat 2.7 cu ft ported tuned at 38 hz was the best for this sub.
If using for max SPL your tuning will be much higher, like around 55 hz. But that all depends on the vehicle.
Posted on Aug 09, 2009
Bolt size for starter 92 tracker
mount starter mount
lost both?
they are both the same diameter.
the length is super easy, measure it.
the leaves, diameter, metric, 8 or 10mm and pitch
so using a box of random bolts with starter off
find one that fits, m8 or m10, or m12.
now you know the sizes, and with starter off the holes are right there. in front of you to test.
to get length, use drinking straw, and your thumb, nail
to find lenght fitted up by and then move straw to ruler, metric
ahhhhhh there is the lenght in 5min work.
if no bolts in the scrap box, at all, metric, buy some.
Oct 30, 2016 | 1992 Geo Tracker
Screw size for mount and tv un32f5500af
This TV is VESA mount compliant with a spacing of 200MM x 200MM. the mount holes are M8 1.25 and about 23MM deep. 3 of the holes are recessed and one hole is near surface. Adding a 2-3 MM margin for a typical washer and the mount itself, M8 1.25, 25MM screws might be the best to mount this TV.
I am using the Sanus simplicity SMF3 mount (bought from costco). The spacers provided with this mount are 22MM which makes the supplied M8 35MM screws too small with the spacers. Without the spacers, the supplied M8 16MM screws are too small. With spacers, I think the screw size should be M8 45MM and without spacers it should be M8 25MM
I am thinking a vinyl washer might be a good addition to the assembly (with my sanus mount).
Found this site useful to understand the screw dimensions.
http://www.fastenermart.com/html/metricsizes.html
Dec 22, 2013 | Samsung Televison & Video
Were is the voltage regulator on a 1991 dodge ram pickup truck
Should be a medium size metal box about the size of a smart phone mounted on the firewall with one harness plug. Usually the box is silver.
Jan 28, 2013 | Cars & Trucks
What bulb is the turn signal bulb on a 2002 oldsmobile alero
On 2002 Oldsmobile Alero Car Light Bulb Size, check this list:
Low Beam Headlight Bulb Size: 9006 or 9006 HID Upgrade KitHigh Beam Headlight Bulb Size: 9005 or 9005 HID Upgrade KitParking Light Bulb Size: 3157NALLFront Turn Signal Light Bulb Size: 3157NALLRear Turn Signal Light Bulb Size: 3157LLTail Light Bulb Size: 3157LLStop Light Bulb Size: 3157LLHigh Mount Stop Light Bulb Size: 921Fog/Driving Light Bulb Size: 894License Plate Light Bulb Size: 194Back Up Light Bulb Size: 921Front Side Marker Light Bulb Size: 194Rear Side Marker Light Bulb Size: 2825Glove Box Light Bulb Size: 194Map Light Bulb Size: 212-2Dome Light Bulb Size: 212-2 or 561Step/Courtesy Light Bulb Size: 168 or 73Trunk/Cargo Area Light Bulb Size: 211-2
Hope helps.
Apr 25, 2012 | 2002 Oldsmobile Alero
Trying to 1ohm my sub for a 2 channel brideable amp
you can only do that if your sub has a switch on it otherwise just hook it up and pound it
Sep 08, 2011 | Alphasonik Mayhem PSW912 Car Subwoofer
How to mount on wall
first you neeed to buy a wall mount kit for your size tv, menards or lowes is cheaper than best buy. you can also purchase a box for behind the tv that has a cable and power supply, it mounts in the wall so you see any wires. you must take the tv base off, normally 4 screws and make sure you have studs where you would like to mount the tv
Aug 06, 2010 | Dynex DX-LCD37 TV
Recall
they can be easily blown/burned out
Jun 03, 2010 | Alphasonik Mayhem PSW912 Car Subwoofer
Which speker box should i use for alphasonik
If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 13 inches x 13 inches x 13 inches
Mar 15, 2010 | Alphasonik Mayhem PSW912 Car Subwoofer
Tv didnt come with screws....
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
Apr 10, 2009 | Insignia IS-LCDTV32 32 in. Television
Need dimensions for CG-5 cinch-down bolt
Don, if you mean the handscrew that retains the mount in the hub, I believe that it's a common 10mm. Should be able to get one a big box hardware. I have seen CG-5s with the hole bored out and retreaded to 1/2NC to mount on a Meade HD Field Tripod. HTH, Geo.
Jan 04, 2009 | Celestron CG-5 Mount Telescope
Alphasonik Mayhem PSW912 Car Subwoofer Logo
258 people viewed this question
Top Alphasonik Car Audio & Video Experts
Marvin
Marvin
Are you an Alphasonik Car Audio and Video Expert? Answer questions, earn points and help others
