Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
The picture is visible but there is an opaque blue area in the picture on the left side of the screen
  • Anonymous Mar 16, 2014
    left half of the screen is dark, but still visible picture, until warmed up. usually after 20-30 minutes. right side of screen is perfect
    Scholar:
  • 88 Answers
Sony bravia
This blue is caused by magnetic fields. Either the speakers of tv is faulty or demagnatziser not working. Switch of tv and remove powercord from wallsockets. Leave for about 10 hours and plug in powercord and switch on. if demagnatiszr is working the blue will be gone. if not have youre tv demagnetized
If hometheatre or radio speakers are closer than ½ meter this could also generate coulouration of screen. move speakers further away. If tv is on and and being moved your static electricity can also cause this. So switch of if if you move your tv.
Posted on Aug 09, 2009
Im having the same problem but it is the whole screen and its been turn off for a week and the screen is still blue with picture any ideas
Posted on Feb 07, 2010
Left side of screen is dark
When you say the screen is dark, do you mean that the picture is still faintly visible or is the left side black with a sharp edge between the black and the visible picture?
If the screen is dark with a faintly visible picture then you have a faulty backlight. This could be due to the inverter board, which can be repaired or replaced, or it could be the CCFL tube which is a bit harder to replace.
If the left side is completely black with a sharp edge then the LCD itself is faulty and may require replacing.
In any case, any of the problems listed above should only be repaired by a competant electronics engineer.
Feb 14, 2011 | Philips Televison & Video
Problem with sony 60" rear projection TV
I'm afraid, it is problem of optical block unit (light engine) that produce picture by 3 lcds inbuilt, the blue lcd and its related uv filters become defective and causing this kind of blue hue on screen.
Complete optical unit block (light engine) will be replaced by qualified tech to get tv fixed, light engine is costly part so ask an estimate before sending tv in.
Thanks.
May 21, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue tint on the left side of the screen
this is caused by the optical block going bad and needing replaced contact sony tech support
Jan 24, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
The left side of the screen has a curve in the picture and there is a blue shadow on the following everything in the picture
you have a convergence problem
there are a couple ics that are used to correct this
it will require service
usual cost in my area are 280 to 320
check with a local servicer in your area
Oct 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
LCD Screen turned opaque at two places, I see two white opaque lines 3 inches wide one on left side of screen and other in the middle
Yes you are correct. I would say 95% of the time, you will need a LCD screen replacement. Also be sure to disconnect and reconnect the lcd cables, at the motherboard and behind the lcd itself, just to make sure the cables aren't making bad connection.
I have provided you a link to MANY lcd screen for your laptop on EBAY.
http://computers.search.ebay.com/Satellite-P100_Screens-LCD-Panels_W0QQcatrefZC6QQcoactionZcompareQQcoentrypageZsearchQQcopagenumZ1QQdfspZ32QQfromZR2QQfsooZ2QQfsopZ32QQftrtZ1QQftrvZ1QQsabfmtsZ1QQsacatZ31569QQsargnZQ2d1QQsaslcZ2QQsbrftogZ1QQsofocusZbs
Hope this helps you. Please rate my solution.
May 16, 2009 | Toshiba Satellite P100 Notebook
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Picture and sound problem at 21" sony waga color tv
This is not a simple question to answer without looking at it, my recommendation is to call a service center in your area. That's my professional opinion.
Feb 04, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Dark screen at top of TV picture
If this is a projection set then a center channel speaker sitting on top would have no effect.
Feb 03, 2007 | Toshiba 46H84 46" Rear Projection...
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
503 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
