Question about Tomtom GPS
My tomtom is waiting for a valid GPS signal all the time
Posted by Palmer Barbara on
5 Related Answers
Anonymous
  • 171 Answers
SOURCE: MY TOMTOM ONE IS WAITING FOR A VALID GPS SIGNAL I
Turn on your tt and let it bootup. After it has booted up go to the map screen. On the bottom right where the bars are for satellite reception. Tap the bars this will take you to the screen telling you the device code etc. On the upper far right where the battery icon is tap the screen again. This will take you to a screen showing the satellites. If you see grey bars on the graph just wait awhile. Sometimes when your tt has not been turned on for awhile or you have turned it on after traveling a few miles it may take up to 30 minutes to get a lock.
Hope this helps
Posted on May 12, 2009
Flat48
Arther Scott
  • 77 Answers
SOURCE: waiting for valid gps signal
Go to TomTom Home on your computer and do a update for your unit. In the update list you should see a GPS quick fix which helps the TomTom's aquire a signal faster. Hope this helps.
Posted on May 23, 2009
Anonymous
  • 47 Answers
The GPS needs at least 3 satellite signals to operate.You are probably in a bad reception area. Move around a bit and try again until you see a signal array of 3 or more!
Posted on Jun 30, 2009
Anonymous
  • 8 Answers
SOURCE: My tomtom one 130 will not pick up a valid GPS
Install Tomtom Home on your pc and connect your gps on it.Do not update the firmware yet, but ony the "gpsfix" program. If it does not work, try a reset by holding the power button for 15 seconds.Let´´s get in touch
Posted on Jan 14, 2010
joseph
  • 229 Answers
SOURCE: my tomtom go 300 keeps reading
i've had the same problem,to fix it you need to update it,i connect it to the computer and go to tom tom home there you can get free updates,i do mine every month,this will fix your problem.
Posted on Jul 04, 2010
Tom tom one XL waiting for a valid GPS signal all the time
make sure the rear of the unit has an unabstructed view out window.
Dec 07, 2009 | Tomtom One XL GPS Receiver
Waiting for a valid gps signal
A couple solutions:
1) Make sure the TomTom can "see" the sky well... the GPS satellite waves are rather weak and easily blocked by trees, and anything not a window.
2) Hook up your TomTom to the computer (see details at www.tomtom.com or in the manual)
2b) Do a "sync" and download all updates. One of the updates is a small file that tells the TomTom where the satellites are located this week, and helps it sync up much faster. The longer time between uses, the longer it takes TomTom to find the satellites, and that can takes up to 2-5 minutes sometimes.
That can be frustrating with a car full of people waiting to get going and the driver doesn't want to drive without making sure the TomTom works and is giving valid directions.
Aug 16, 2009 | Tomtom One XL GPS Receiver
Waiting for valid gps signal
Jun 30, 2009 | Tomtom One XL GPS Receiver
My tomtom cant find any satellites and keeps saying waiting on valid gps signal......
check the port is set to 8
not sure if your model has GPS search wher it finds the port and vbaude automativcally, if it does use it and see if that fixes it if not
your battery is too low
you have a damaged SIIRF chip and that is expensive to repair
Jun 01, 2009 | Tomtom ONE GPS Receiver
May 21, 2009 | Tomtom One XL GPS Receiver
In the car my tomtom is saying waiting for a valid GPS signal
press the reset button on the side and wait for about 3minutes...
Mar 29, 2009 | Tomtom ONE 3rd Edition GPS
Tom tom comes on but,no gps signal lost for hours.
hi you need to reset the unit at the back near the connection there is a small button that needs to be held down when holding the power button on for a few seconds. once you have done this turn it on and it will work fine
Feb 11, 2009 | Tomtom GO 910 GPS Receiver
"Waiting for a valid GPS Signal...."
the unit will only connect with the satelites out doors my man
Dec 22, 2008 | Tomtom ONE GPS Receiver
Tomtom stuck on waiting for valid GPS signal for 3 days
u need to up date gps if that dose'nt work sounds like it needs to be repaired i had same problem and found its better to buy new on then pay 275.00 to repair due the math
Dec 15, 2008 | Tomtom ONE GPS Receiver
GPS Logo
181 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
