IBM ThinkPad X41 Tablet PC Logo
Posted on Aug 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After reinstalling XP on T42 I can't turn on the wireless network
After reinstalling XP on my T42 I cannot turn on the wireless by means of "Fn + F5" - only Bluetooth. The T42 does not have a fysical switch on the front panel.
Also the Access IBM button does not work at all. Nothing launches when I push the button. I have tried to use a USB wireless network adapter which works fine and the machine can surfe the net again, but I would prefer to get the internal wireless adaptor to work instead.
I can see that many others users posted this problem, but I cannot find a usable solution yet on FixYa.
Paul Hutchinson
Level 3:
  • Master 909 Answers
  • Posted on Aug 09, 2009
Paul Hutchinson
Master
Level 3:
Answers
909
Questions
0
Helped
273061
Points
2687
Check that the correct device driver is installed using the device manager via the control panel.
Download driver max to automatically check all your drivers for free.
No wireless adapter
Have you check the wireless card under the Device Manager?
Start->Control Panel->Device Manager
Under Device Manager look for Network Adapter there will be sub folders under network adapter look for the wireless device. If its not showing it means that the Device is not working. If you want to make sure try to reinstall the Operating System and after that check again the Device Manager.
Cannot connect to internet throught wireless networks. it used to show the networks available when it turned on but does not do this anymore i can connect through a cable running through the wireless...
This may be a really stupid response, but HPs (maybe only their tablets?) are notorious for randomly shutting down the wifi connection - I know it happens on my TouchSmart. Just as a precaution, check to see if the wireless LED is off or has turned red (on newer models it's at the top of the keyboard toward the right) and try to toggle it using either the hardware switch or Fn-key combo specific to your machine.
Hope this helps, as obvious and trivial as it may seem!
1helpful
How to connect wifi network in archos 28 internet tablet
This is normal. To save energy, the ARCHOS always starts up with the WiFi set to off. You must manually use the Fn-F3 keys if you want to activate the WiFi connection.
I cannot connect to the Internet over WiFi, what's wrong? Make sure that your WiFi is activated. This can be turned on and off with the blue function key pressed down and then the F3 key. The blue WiFi indicator just below the touch-pad will light indicating that it has been turned on.
My WiFi router/modem is on and working, but it does not show up in the list of wireless networks. What's wrong? It could be that the WiFi modem/router is hiding its SSID. This is done for security purposes sometimes. You can either change this on the WiFi modem/router (see its instructions) so that it broadcasts its SSID (and then you'll see it in the list on your ARCHOS 10) or you can go into the advanced settings of the Wireless Network Connection screen to the Wireless Networks tab and 'add' a new connection. You will need to know the SSID name and its other connection parameters.
My hp tc4400 will not start up, I can hear the fan and the green button flashes any help would be great
Try pressing the fn key and F5 key together at the same time.sometimes the sticky keys just seem to kick in. if not F5 key it will be one off the other F keys dont forget fn+ F5 or other.
hope this helps
I need to put the laptop on a monitor but screen
Usually FN and F5..............Try FN with other F? keys if it doesn't work with F5
1helpful
Wireless network does not work on ix300
try to reinstall your wireless network driver. is same issue occur. contact your manufacturer and have your wireless card replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
1helpful
Problem with bluetooth , as well Fn+F5 combination doesnt works
I think that you must re-install your bluetooth and wireless software.
2answers
Wireless LAN Adapter
Go to driveragent.com and let it scan the laptop to see what drivers are missing.
1helpful
WLAN disabled after clean reinstall of XP/Drivers
If you haven't got the wireless network icon in your system try, Try going to Services under control panel - administrator tools and starting the Windows Zero Configuration Service. You'll need to set it to automatic so that it's running when you restart
2answers
Cannot access WLAN after clean reinstall of XP and drivers
make sure the drivers are installed. check in device manager under network devices. also make sure u have wireless zero config service running. click start..run..type services.msc, scroll to bottom, right click and start the service
Top IBM Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an IBM Tablet and eReader Expert? Answer questions, earn points and help others
