Question about Electrical Supplies
Generator is running but no power - Electrical Supplies
Posted by April Smith on
sherlywang
    Master:
  • Electrical S... Master
  • 425 Answers
Here is the solutions for your question:
1. Measuring whether there is real electricity, the generator replaces the voltmeter.
2. Put it into automatic or manual mode.
3. Check and correct according to the circuit diagram.
4. New generators or machines that have not been used for a long time appear easily. They can be charged by charging buttons on the control screen or by 12V batteries. The positive pole is connected to F1 and the negative pole is connected to F2. If the voltage can not be established, the positive and negative poles of the batteries can be changed and retried.
5. Cleaning is the surface of the ring. The end surface of the carbon brush is sanded so that it coincides with the arc on the surface of the collector ring more than 70% and the spring pressure is strengthened.
6. Clean carbon brush and carbon brush grip make carbon brush move freely.
7. Check the forward and reverse resistance of the diode with the multimeter, such as damage and replacement.
8. Use a multimeter to check if the forward and reverse resistances do not meet the requirements of diode characteristics. If the resistance value is infinite, the multimeter 1K for diesel generator sets should be turned on. Then use one Eurometer to check if the resistance value is zero, replace or handle the windings. If the resistance value is not stable, check whether the connection of the joint is loose.
More solutions from the website:
https://www.dieselgeneratortech.com/
Posted on Aug 19, 2019
The engine is running but does not have power.
If the generator has been sitting for a long time or was shut off with the load connected it has likely lost the residual magnetism that is required to excite the winding. This is a common problem. Always disconnect the load from the generator before stopping the engine!
The generator needs to be flashed. There are several was to achieve this, but safest would be to use an electric drill.
  • Connect an older style portable 120 volt drill to the running generator.
  • Make sure the drill is in forward not reverse
  • With the switch depressed rotate by hand the chuck of the drill in reverse
  • careful, the generator will flash, power up and rotate the drill in the forward direction..
Hope this helps?
  • Careful the generator will flash the windings and power up the drill
Mar 28, 2016 | Electrical Supplies
I have a nikota 3500 watt generator and I am not getting any power from the generator. Motor runs fine just no power. Is there anything I can check.
All Power America APG3535CN, 2800 Running Watts/3500 ...
www.amazon.com/...Power...Generator/.../B000U0OJ...
Amazon.com, Inc.I then call All Power and am told to give them one more day to get this worked out ....There is no styrofoam enclosure or crate to protect it, the generator is simply ...
NIKOTA 3500 WATT GENERATOR - YouTube
? 0:58
https://www.youtube.com/watch?v=NEeu9Y-0_KM
Aug 27, 2011 - Uploaded by mamasboypowersports
NIKOTA 3500 WATT GENERATOR. ... Diagnosing A GeneratorThat Has No Power Output. - Duration: 3:03. TheDIYGuyDOTnet 117,263 views.
I have a nikota 3500 watt generator and I am not getting any ...
www.fixya.com/support/t26062098-nikota_3500_watt_generator_am_not
2 hours ago - I have a nikota 3500 watt generator and I am not getting any power from the generator. Motor runs fine just no power. Is there anything I can ...
Generator outputs low variable voltage, ideas for troubleshooting ...
www.smokstak.com > ... > Generators & Motors General Discussion
Jan 20, 2016 | Electrical Supplies
Why would my generator engine runs great but it will not power any of my tools. what could be the problem?
With no load on the generator, take a voltage reading at the output plug of the generator, if there is no voltage, check to make sure that no breakers are tripped or fuses blown.
Sep 21, 2014 | NEC Mitsubishi MGE 4000 Generator ROU...
Sigma 6500E generator
First verify that the breaker for the outlets is not tripped and make sure that the generator is running at full operating speed. let it run for 5-10 minutes and check for output power. If there is nothing, there are two possible problems. One could be that the automatic voltage regulator is bad. The other is that the field needs to be flashed - a high possibility if the generator has not been run in a long time. There are many videos on the internet that show you how to solve both of these problems. Just do a search for No output from a portable power generator.
Mar 20, 2014 | Sigma Powers Inc Rural King 6,500 Watt...
Onan 7000 generator runs but does not produce electric to rv
Mar 19, 2014 | Watts Onan Portable Generator - 4000 ,...
Can my eb5000 generator run an electric 7hp compressor
7 horsepower is approx 5150 Watts so the compressor would be taking this power while running. On startup however the compressor can take a surge of upto 3 or 4 times this power so the generator wouldn't be able to supply this demand . In any case it's not advisable to run a compressor off a generator unless the generator is high powered, 20KVA or greater for 7hp.
Mar 31, 2011 | Honda Mmd 5000 Watt Generator W/ Engine...
Generator runs fine but doesn't get power to the air conditioer or fan which run ok when plugged into ac power
An air conditioner is an appliance that draws a fair amount of current. It would have to be a large generator to run an air con. Does the generator run smaller appliances like a jug for instance. If it does this means that it is working okay, it just can't handle the capacity of an air con.
Feb 11, 2011 | Watts Onan Portable Generator - 4000 ,...
No power to coach when generator runs but power
Do you have automatic switch over in your system, or is there a receptacle where power cord stores, that you need to plug power cord into, for power from generator?
Oct 13, 2009 | 2002 Ford E350
Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Mar 24, 2009 | Yamaha 4500 Watt Electric Start Generator...
Electrical Supplies Logo
135 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
