On/off light and energy save lights are flashing on a hotpoint WF000. When I unplug and restart the machine on a wash, it'll run for a while before flashing the prewash light as well as the normal running lights. In this error condition the machine continuously fills and pumps out at the same time - high water level present in the drum. Any ideas?
problem seems sorted: Initial error occured when trying a test run (fast spin) with an empty machine. Thought it was a load sensor. Tried it again with the wash selection on fast wash with machine off, switched off and on again, pressed and held start/cancel and then start again. Rn through complete cycle no problems. fluke??problem seems sorted: Initial error occured when trying a test run (fast spin) with an empty machine. Thought it was a load sensor. Tried it again with the wash selection on fast wash with machine off, switched off and on again, pressed and held start/cancel and then start again. Rn through complete cycle no problems. fluke??
You can't post conmments that contain an email address.
2 things, never run a machine empty, at least place ina light load. second, the original problem may have been too much soap in a load, thus confusing the water level sensor.2 things, never run a machine empty, at least place ina light load. second, the original problem may have been too much soap in a load, thus confusing the water level sensor.
when the washing maschine is switched on all the lights are flashing,...you can´t switch that on or off,..you have to unpluged the maschine,...we are unable to wash any clothes
Hi Snarey, it sound like your door lock has passed away, you will need to make sure the appliance is unpluged, empty the water out of the drum, and check the vacuum switch which opperates the lock.
I had the same problem with our hotpoint aquarius WT540P , I contacted EMW electronics who told me it was most likley the Computer board. They supply reworked replacedment boards on an exchange basis. I installed the replacement and the machine's been washing away merrily since. Here's a link to there web site. http://www.emwelec.co.uk/ .
Regards.
Nigel
check your pump for any blockages it may not be pumping out fast enough the tomer only gives the pump a certain amount of time to pump all the water out if has got some blockage than clean out and this should sort the problem out always check pockets if this is no help let me know and ill let u know what else it could be m8
