Broken glass top inset ''burner ring''
If you are referring to the bakelight material, this is an insulating compound and the burner still may work. I would not use this long term in this manner however. This material insulates as well as helping maintain an even heat transfer of the burner. Long term use, may cause damage to the cooktop. The burners are replaceable, but the prices vary depending on the size of the burner. The part numbers are as follows:
6" radiant heat burner - WB30T10129
8" radiant heat burner - WB30T10132
9" radiant dual heat burner - WB30T10133
You can view these parts at searspartsdirect.com under the "Cooktop" heading. You may find the parts cheaper at these other websites, by searching for them using the part numbers provided:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary at the other websites. Sometimes they may not carry the model number, but the part numbers are still listed.
If you have further questions, please post back and let me know. I hope this helps you.
