Question about Lands Phones
Number of rings before going to VM I have a cordless phone KX TGD530
Posted by Vicki Hagerty on
'Dan Carron
Usually 3 or 5. Phone it from another phone and see
Posted on Jun 19, 2019
  • 1 more comment
  • Vicki Hagerty
    Vicki Hagerty Jun 19, 2019
    3 rings only not seven
  • Vicki Hagerty
    How do I fix this??
  • 'Dan Carron
    'Dan Carron Jun 19, 2019
    Usually in the settings. Google the manual, it will be innthere
Answer too fast
Here is a link where you can download the user manual for free which will explain how to set the phone to answer after a certain number of rings. Just go to the link its already set up just click on the download link.
http://www.retrevo.com/s/Panasonic-KX-TC1743W-Telephones-review-manual/id/2914bh651/t/1-2/
Mar 23, 2008 | Panasonic KX TC1743W Cordless Phone...
How do I change the amount of rings before it goes into VM?
I think you would have to access the firmware via a terminal so if you know the quad ie.192.168.x.x 'x' being any number between 0-255 includeing zero and hitting connect then you should be able to access this stuff via the firmware menu.
Mar 04, 2015 | Panasonic KX DT343-B Digital phone - Black
How do I change the number of rings before the answering machine picks up the call on my panasonic KX-T7633 phone
If this is forwarding to the answering machine on YOUR phone, from the intercom dial *713xx where xx is a number of seconds. I think by default it's using the system number of 40 or 45 seconds. Try 24 for 4 rings (or multiply the number of rings by 6 and you get seconds).
If you're talking about SYSTEM rings before the VM, it's a different story and it requires system programming.
Carl
Aug 24, 2011 | Panasonic KX-T7633 Corded Phone
Changing the voice mail access number.
press menu
arrow down to "Initial setting"
press select
"voice mail" will sow on the screen
press select
"store VM access#" will sow on the screen
press select
edit the number and press save
Dec 20, 2009 | Panasonic KX-TGA630S Cordless Expansion...
Set number of rings
First press the menu button then scroll up or down to "initial setting" and press the select button. then select the set answering option then select the number of rings option now you can select the number of rings by scrolling up ^ or down. or you could just press the number on the keypad. Once you have selected the amount of rings you want press SAVE, then press off and your all set.
Mar 05, 2009 | Panasonic KX-TG2382 Cordless Phone
Panasonic KX TG1100 base unit does not ring
I do not think there is any chance to make the base ring for this particular phone. Anyhow, if you discover how to do it throw me a note.
Nov 20, 2008 | Panasonic KX-TG1100 Cordless Phone
Panasonic kx tg5672
head sets will not conect to home base
Jan 30, 2007 | Panasonic KX-TG5672 Twin Cordless Phone
Lands Phones Logo
116 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
