Question about Cycling
Are the pedal straps available for purchase for the 310R?
Posted by Leslie MacMillan on
Where do I get pedal straps for my vital fitness rb 330?
There are multiple sources of "universal" exercise bike pedal straps:
exercise bike pedal straps Google Search
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Aug 24, 2017 | Cycling
Tip
Installing a Pedal Strap onto a Bike Pedal
Video about How to Install a Pedal Strap onto a Bike Pedal
  • This procedure will demonstrate how to attach a pedal strap onto a pedal
    • This is even easier when the pedal is attached to the bike but we did not have a bike available so we are showing how it is done with the pedalremoved from the bike
      • Tip: Soaking the pedal straps in hot water can make the strap installation even easier as the hot water will soften the rubber making it more pliable
  • Start on the inside of the pedal (nearest the pedal shaft) by placing the slotted hole in the strap at the bottom of the tab and pulling the strap up and into place as seen in the video
  • Then with the tab on the outside of the pedal, start at the bottom and push the strap up and around the tab into place
  • This is all that is required to install a pedal strap onto a bike pedal
  • That completes the procedure
Installing Pedal Strap onto Stationary Bike Pedal Video
on Apr 28, 2014 | Exercise & Fitness
Searching for the proper pedal safety strap that will hold my artificial leg on the right pedal.
try places that deal in artificial limbs and items for immobilized people and see if there is such a strap made for your requirements
if not , it may be necessary for you to obtain the help of an upholsterer to design, fashion and construct a suitable strap for your application
something like a riding stirrup that has an enclosed toe piece welded to the pedal and a strap around the heel would be a idea to start with
just a suggestion
Jul 09, 2017 | Baby Gear
Need replacement pedals for my resistant exercise bike
Rob, try any sporting goods that carry bicycles or bicycle repair shop for replacement pedals or order online.Check the attached links for replacement pedals. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
VP Exercise Bike Replacement Pedals 1 2 Stationary Bicycle Pedal Set with...
Parts for Life Fitness Bikes Pedals Battery Pedal Straps SPORTSMITH net
Exercise Bike Pedals eBay
Apr 12, 2016 | Cycling
Strap for watch
IN the past rather than finding bands specific for a particular brand of watch I have had good luck simply using one of the many universal fit bands available from various sources. Simply hold them up to your watch to determine compatibility and whether you like the look.
Nov 15, 2014 | Nautica Watches
My Dad is 87 years old and has a small peddle stationary excersiser that he does from a chair. The peddles are too small and he keeps hitting his ankles etc. His feet don't fit into the straps and he's...
You will need a pedal wrench or a fairly thin open end wrench. Pedals are threaded or a good pedal wrench. The left pedal on bicycles unthreads in a clockwise direction and the right pedal unthreads in a counterclockwise direction. The thread back in oppositely. Theoretically they self tighten as you pedal. When buying the new pedals, make sure you take an old one with you to make sure that the threaded shaft is going to be the correct diameter. Any fairly wide pedal with rubber grips would be a good choice. A past customer even used two blocks of wood screwed together through the old pedals as they were too tight to remove. Hope this helps and wish your Dad well.
Apr 23, 2009 | Cycling
Cycling Logo
167 people viewed this question
Top Cycling Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Cycling Expert? Answer questions, earn points and help others
